coilovers?
Old Jul 16, 2012 | 12:46 AM
badchad23's Avatar
coilovers?
have a 2010 RG Ralliart that i use as DD. No tracking other than occasional fun night at dragstrip. lowered on eibach pro kit. is it worth the money for ride quality alone to buy coilovers? is it a big diffrence? wouldnt mind lowering it a little more then the eibachs do in summer and raising it up some for winter, but mainly looking for ride quality. 29000 miles on the eibachs and stock struts , so maybe thats the reason for the bad ride quality. if im gonna spend the money for new struts i was thinking of going coilover route. let me know your opinions please. thanks
Old Jul 16, 2012 | 06:52 AM
evo_soul's Avatar
You may wish to consider coilovers since it sounds like your current OE shocks are at the end of the their performance life with aftermarket springs on it. KYB OE Lancer / Ralliart shocks do not take well to being lowered at to it year round operation, I am pretty sure you will have to consider coilovers.
Option 1 would be Damper replacements from KYB.... currently the only Tier 1 company offering aftermarket shocks. Then purchasing a more aggressive drop springs.
Option 2 multiple adjustment coilovers would be optimal. I typically recommend Monotube coilovers over twin tube unless you know for a fact that you will never track the car. Drag strip is ok. Twin tube can last a long time so long as they are not subjected to abuse. Monotube is pretty good but there is still a quality range. Also there are some kits that can go lower than others. If Maximum drop is what you are looking for then you should do some research to see which kit provides the most drop.
My recommendation is HSD coilovers for an Inverted Monotube coilovers for a compliant ride and track worth performance adjust-ability. For a simple drive (daily driver) consider the Tein Basics. They offer a nice range of ride height and its a pretty reliable twin tube. My research into the Tein Basic yields very low failure rates during the first year and a good life after the first year.
Hope that helps.
Old Jul 16, 2012 | 11:12 AM
badchad23's Avatar
Thanks
Old Jul 26, 2012 | 07:11 PM
p1llar's Avatar
Who makes these? I wasn't aware that one had come out
Old Jul 27, 2012 | 12:49 PM
Veronica's Avatar
Your best ride quality for DD is on the Eibach/ProKit.
Get new struts (only).
Old Jul 30, 2012 | 08:02 AM
evo_soul's Avatar
http://www.tirerack.com/suspension/S...dClar=Ralliart
KYB is the OEM manufacturer of Lancer and Ralliart Dampers.
KYB made an aftermarket variant that is a little firmer but still of the same design as the OE. Its valved better and is more tolerant of aggressive drops which makes it a good way to go and will give you 2 good years before it degrades. Vs. 1 years of a factory OEM version which can not handle aggressive or even mild drops without blowing, leaking or degrading.
The coilover option if you buy a good quality one may be a better investment in the long run for performance gains, height control and longer life.
Old Jul 30, 2012 | 12:11 PM
Veronica's Avatar
^Good find!
Old Aug 1, 2012 | 04:57 PM
neogeo64's Avatar
I have not found a source in the US that will sale these. I'm guessing you have to order them overseas. Also I did not see the Ralliart on their application list?
I'm going to finally get some coil-overs for my car this month with a budget of 1500. I'm seriously considering The Fortune Auto 510's.
I have been hearing nothing but good things about them in different forums and they make a set specifically for our cars.
Old Aug 2, 2012 | 09:56 AM
evo_soul's Avatar
Fortune is certainly an option to consider. Many on there have good things to say about them.
Rick Chong / Scorpion is opening a west coast location already and they are an HSD distributor. That is in Anaheim I think. You can email him for a quote at RickChongUSA@gmail.com If you were closer to the facility you could even arrange install as well. If not, then get a quote for shipping. Cant be that much.
Old Aug 2, 2012 | 02:37 PM
sstevojr's Avatar
I ordered a set of 510's last week, s/b here in a couple more weeks.
Old Aug 2, 2012 | 05:20 PM
billyboy1's Avatar
the fortune auto coilovers looked pretty good - they were on the list to purchase, before i just re-built my old ones (that and cusco)
Old Aug 3, 2012 | 02:54 PM
nunyas's Avatar
i'm interested in how these feel. From the shock dyno plots, I would imagine them to seem a bit softer but way more controlled (than BC Racing BR coilovers) on the rebound side. But then IIRC the FA 510 series standard spring rates on them are 8k/7k for the RA (similar to what you're running on your BC BR's isn't it?).
Old Aug 3, 2012 | 04:01 PM
sstevojr's Avatar
FA's are custom built, so there are no "standard" (but IIRC they say recommended or something in their chart). For instance I've ordered them with Swift Spring upgrades (yes again, that's how awesome Swift springs are, even in coilovers) @ 9k F / 10k R, BUT with Street valving. The idea is firmer springs to better absorb heavytrack abuse, but moderate valving so I don't destroy my spine DD. And the UDDP valving look like they are worth the price increase over standard 500 series.
What I really liked about the shick dyno is the driver input part, they appear to be very controlled. This should really help stabilize weight transfer in hard cornering, an area my fat *** needs a bit more help.
Old Aug 3, 2012 | 11:06 PM
neogeo64's Avatar
sstevojr, Do you mind posting up an unboxing & review with pictures? I may base my purchase off your review of them.
Old Aug 4, 2012 | 11:40 PM
xRANGERxDANGERx's Avatar
does anyone have any deedback on the eiback multi pro r1 coilovers? seriously considering getting them.
