19 inch wheels on ralliart.
Hey Guys,
I am looking at getting a set of 19 inch wheels for the Ralliart. I wanted to know what offset and and wheel width would fit without rubbing on stock suspension. I am interested in 8.5 with like a 35 offset. I know there is a sticky thread that explains about all of the different sizes. But nothing about 19 inch wheels. Any help would greatly be appreciated.
Thanks!
Thanks!
With that aetup at atock height the wheels will poke outside the guards scrub on the rear. Lowering the car and getting the guards rolled will fix the issue. Remember not to go too tall a tyre to save yourself some issues.
8.5inch wide with 35 offset its basically an orm x fitment. Instead of a 245/40 18 like an evo woukd run, get a 235/35 or similar to keep the overall tyre circumference the same ish as stock
Depends if you like wheels sitting outside the guards mexican style. They will poke out 41mm more (1.6inches) more than your stock wheels. At stock height you may get away with it but in my opinion it will look weird. From memory 9inch wide et40 is reasonably doable. More than enough wheel for an ra
awd2gen
Dec 12, 2014 11:05 AM
evovin
Mar 13, 2008 10:44 PM
evodave
21
Jul 23, 2005 10:17 AM
