Just ordered X Turbo
WHP and TQ are two different factors and TQ is the limiting factor on the clutch and trans.
It is and will be possible to achieve 300+whp on the Evo X turbo with the current stock SST trans.
Yup, the review of Ismael's car will be up shortly. Evo X turbo with supporting mods sets a record for the Ralliart 2009!
The aftermath of his leaking stock turbo oil seals when he originally blew the stock turbo is the source of the smoke. The turbo blew out on another tuner's tune.
Our dyno is dead nuts especially on SST cars on the 1320' testing.
My daily driver did 133mph on the dyno and 134mph at the dragstrip.
If it does 110.2 on the dyno, Izzy should do 110-111mph at the track and its only getting colder from here.
Different dynos have different readings. TTP's reads a little on the high side, but again, it's all relative. If memory serves, AMS's RA with an EVO X swap was 300 whp/ 310 wtq... so about a 12% difference, it looks like.
Yes and it does about 370 whp on the Red.
So if this car puts down 346 on TTPs dyno and it reads approx 7%? lower than a Dynojet, then it should dyno about 370 on any Dynojet 424X. If that's the case, then yes it should run 113-114 mph and I would LOVE to see that happen.
