Stock EVO X Intercooler & Piping
so quick question, for you ^^^^
this may sound stupid to you guys, but it's important to me since I'm driving my car daily.
If you were to put the intercooler up in the air, would you be able to see a little bit of light through the fins?
If you have any questions, let me know!
Thanks,
Michael
I put an evo x intercooler on my ra. When and if you do get one you need the evo x upper pipe. Also you'll need a larger coupler for the bottom pipe. You can get those usually at your local parts store. I'd say it was an easy instal the hardest part was taking off the front bumper which really isn't that hard.
I will try to do some logs to see what the difference is. Also if you have questions about the instal just PM me i'd be happy to help. I'm in northern NY so any one close i can help you with the instal.
IF! you get the Evo X intercooler, and you require the Evo X pipes, then that means you can also get HKS pipes for the Evo X and have them installed in the Ralliart? am I right? unless the intake from the turbo to the upper pipe is a bigger diameter (which i think it is)....
Any new pics of FMIC and Ic Piping installed. With X top IC pipe can u still put engine cover on? Good info, thx.
