ecu flash
Old Aug 16, 2009 | 07:12 PM
Veronica@TTP's Avatar
Originally Posted by RotorGlow
I've got a stock car with just a tune, and there is no way in hell that im getting 13.2-13.3
If I were to guess, I would say 13.8
Here is a personal account from one of our Canada customers.
Originally Posted by Customer Account
----- Original Message -----
To: sales@ttp-engineering.com
Sent: Wednesday, July 15, 2009 5:21 PM
Subject: RE: Ralliart tune
I just ran 13.33 102 mph with your new map!!! The car run great..no more black smoke!!!! thanks a lot!!
To: XXXXXXXXXXXXX
Subject: Re: Ralliart Tune
Date: Mon, 6 Jul 2009 2I2:24:10 -0500
Try this map
__________________________________________________ _
Sent: Monday, July 06, 2009 8:48 PM
Subject: RE: Ralliart Tune
here my car info again: Lancer ralliart 2009 with a boost pill....All stock.....I did 14.1 95 mph complety stock.. I am from quebec canada....
Old Aug 16, 2009 | 07:59 PM
RotorGlow's Avatar
Well I'll be taking my car to the track once I get my new downpipe and testpipe...Then I'll have some solid numbers to show off, rather then guesses.
"Lancer ralliart 2009 with a boost pill....All stock"
A boost pill is an upgrade, so technically it wasn't all stock.
Don't get me wrong here, I love TTP
Old Aug 16, 2009 | 08:26 PM
TTP Engineering's Avatar
You can accomplish the same effect of the boost pill by removing the 2nd pill in the solenoid line or installing a bleeder inline to the solenoid input.
Old Aug 16, 2009 | 08:36 PM
RotorGlow's Avatar
I don't suppose you have some pictures as to where I could find that 2nd pill. If I remove it, will I need another tune?
Old Aug 16, 2009 | 08:39 PM
If you take off the 10mm bolt on the back of the airbox, the solenoid can be moved to gain access to the lines. The line to the solenoid from the TURBO not the intake can be removed and about 2-3 inches into the line there is a pill that can be worked out of the end of the line which should increased boost about 2psi or so.
Old Aug 16, 2009 | 08:42 PM
RotorGlow's Avatar
Looks like I have a project for tomorrow
Old Aug 16, 2009 | 09:07 PM
chubbs488's Avatar
Will removing the 2nd solenoid have any bad effects on the car. Like rotor said will this require you to get a tune?
Old Aug 16, 2009 | 09:12 PM
GiLizILL's Avatar
Just a tune?
They send you a timeslip too?
That seems a little hard to believe.
Not taking any credit away or anything.
But like I said AMS was full stage 2 running 12.9-13.1 at 102-104.
and AMS isnt known for being "slow"
but hey, maybe he calculated sea level into his timeslip
Old Aug 16, 2009 | 09:16 PM
RotorGlow's Avatar
Removing the solenoid WILL...it's the pill leading to it that wont
With more boost, you would think you would need more fuel. Which in turn means a new tune...but I would like TTP to answer...
Old Aug 16, 2009 | 09:54 PM
chubbs488's Avatar
^ ha ha I should have been a little more specific, and yes I would like to know ttp's answer also im trying to decide on which tune to get not that that would make a difference but i would like to see a timeslip with just a tune
Old Aug 16, 2009 | 11:58 PM
When you get our tuning, we just need to know what method you are raising the boost with, if at all.
Old Aug 16, 2009 | 11:59 PM
Originally Posted by IdriveRA
Just a tune?
I sent him an email to see if he has the slip for us.
We ran the last car on the dyno to 13.3@102+ with 2.2 60' time. Not sure how to launch these.
Old Aug 17, 2009 | 05:34 AM
There is only one solenoid on ralliart, but 2 pills.
Old Aug 17, 2009 | 08:25 AM
GiLizILL's Avatar
stock/tune?
as in just a tune, normal gas, lol...normal oem everything.
a 1.8-1.9 will put you in the high 12's
Is that really possible?
