TC-SST tweaked?
Old Nov 4, 2009 | 04:40 PM
  #46
Ladogaboy's Avatar
TheSin used SSP's clutch plates; he just did the install himself... in his own garage.
Old Jan 9, 2010 | 12:10 PM
  #47
TheSin's Avatar
Yes it was the first set of the SSP clutches in the wild that I had, Install isn't bad getting the trans out and in the car is the worst of it.
Just remember though there is lots of programming that still needs to be sorted, I did the clutches right away cause i know I"ll need them, but until all the programming is sorted you won't see massive gains for the MR, but ti's being worked on and if things time out well I'm hoping to lay down 500-600hp in spring. Using the SSP Clutches
