problem?
Old Aug 7, 2010 | 04:18 PM
MikeRA87's Avatar
problem?
Car is idling funny when just sitting there and when i jump on it itll backfire at high rpms or redline? I was just driving and all of a sudden all of this started happening..i think it might be an air fuel problem
Old Aug 7, 2010 | 04:30 PM
evilempire18's Avatar
Do you have an engine light on? if so what is the code?
Old Aug 7, 2010 | 04:34 PM
jkennedy293's Avatar
Did you fill it with 87?
Old Aug 7, 2010 | 04:47 PM
MikeRA87's Avatar
no engine light and i use 91 octane
Old Aug 7, 2010 | 05:15 PM
Tommy Di Cat's Avatar
With no code it's kinda hard. I ve read alot of people with MAF issues on a open filter or k&n because of the exra debris and oil build up. Maybe check that.
Old Aug 7, 2010 | 05:29 PM
MikeRA87's Avatar
i have a zeitronix AFR display and when the car is idling at a stop the afr is bouncing all over the place from the 12 to 18
Old Aug 7, 2010 | 07:01 PM
SOG RA's Avatar
Check the vacuum line going into your fuel pressure regulator, if you lift up your engine cover its at the bottom left hand corner, make sure thats on there good. I really doubt its due to your air filter, but MAF issue is definitely possible. Best thing to do would be call your tuner, tell him the issues that your having. It could be a number of things but most definitely something related to air/fuel, but I would check that vacuum line going to the fpr first, call tuner and go from there. My guess is, its something pretty easy to fix.
Old Aug 7, 2010 | 10:25 PM
MikeRA87's Avatar
yup definitely was the vaccuum line, it was disconnected
Old Aug 8, 2010 | 07:35 AM
mikesim's Avatar
zip tie that ****! lots of X owners have this problem too.
