FP Red 18 psi wastegate option
Old Aug 12, 2010 | 04:12 PM
bsvaton's Avatar
Question FP Red 18 psi wastegate option
Can someone explain why it cost an extra $100 for the 18 psi wastegate actuator? I am still somewhat new to turbochargers but I am thinking this means the wastegate is going to kick in at 18psi correct? I thought everyone running the fp red was running at least 20 -22 psi and I hear up people up to 28 psi. Please let me know if this means I will not get more than 18 psi of boost and if so how can I increase it? Thanks
Old Aug 12, 2010 | 04:28 PM
Smokahontus's Avatar
the spring is loaded to hold at least 18 psi. The rest of the boost retention is done via the ecu.
Its just a stronger spring. I believe the normal one is 12 or 14 psi.
Old Aug 12, 2010 | 07:19 PM
zato112's Avatar
18 psi ,means the wastegate actuator is fully open at 18 psi, the ecu adds a duty cycle to the boost control solenoid which bleeds off some of the boost pressure that will then allow higher boost pressure.
you can also use a manual boost control valve that will do a similar job of bleeding off the air to the wastegate actuator.
Old Aug 14, 2010 | 05:41 AM
03chi-town0Z's Avatar
^ basically. the stronger wastegate spring will hold boost longer and limit taper
EVO8LTW
30
Oct 29, 2018 03:17 AM
BOOSTINAT30PSI
24
Feb 8, 2017 07:48 PM
06rallyred
Sep 4, 2014 09:30 AM
rjfg
21
Jul 30, 2014 03:46 PM
zenoise
50
Apr 29, 2013 10:03 PM
