ralliart questions (n00b)
Old Nov 25, 2010 | 11:15 AM
RazorLab's Avatar
Originally Posted by netnews
#2 - is stock evox/ra turbo really 40lb-min?
The TD04 RA turbo is *much* smaller then the TD05 Evo 10 turbo. It's also single scroll instead of dual scroll like the Evo 10.
Lots of good info logged in this thread I started over a year ago:
https://www.evolutionm.net/forums/09...ns-o-data.html
The stock Evo 10 turbo logs approx 41-43 lb/min depending on mods and tune.
The stock RA turbo logs approx 31-33lb/min depending on mods and tune.
So approx 10 lb/min more with the Evo 10 turbo...
Old Nov 25, 2010 | 04:26 PM
NFSLancerRA's Avatar
Originally Posted by SSP Kris
The ECU of both vehicles tells the TCU to execute certain functions. The launch control and traction control are directly controlled by the ECU. The TCU only interprets what the ECU tells it to do...
So, the S-Sport mode is only in the ECU? What would it take to program such a thing into a Ralliart ECU? Have you figured out where this piece of software is yet?
Old Nov 26, 2010 | 10:20 AM
netnews's Avatar
correct, the ra has a tod04...
if my "deal" works out.. on a salvaged ra, i would upgrade it .. the question is to what..
currently thinking a evo x manifold and a 20g (or fp-red) -- depending on the web site seems that's a 44-49lb-min, flash, injectors, dump exhaust.. and that should do it.. for 300+ whp
(i love the SRT-4, fast/cheap/easy mod... traction is a serous issue 350-400whp in 1-3rd gear)
Originally Posted by mikesim
i thought the RA turbo is a TD04?
Old Nov 26, 2010 | 07:09 PM
jimbo4510's Avatar
the tcu controls lunch control i guy in a other forum blow up his sst and the got a mr one from the wreckers put it in now he has lunch control and we do have the same crank as the evo
Live4Redline
Mar 27, 2026 01:19 PM
WeirdGuyXp
Nov 23, 2015 02:39 PM
BrunoBoy650
Feb 27, 2014 12:10 PM
VTEC Killer
39
Apr 17, 2009 09:32 PM
Diavlo
Dec 25, 2006 03:44 PM
