boost controllers
Old Jan 14, 2011 | 08:14 AM
elmerfud54's Avatar
boost controllers
im looking to buy a boost controller, i want to get some feedback as to what kind you guys are using and the ease of use. searched the ralliart threads but havent found one on this
Old Jan 14, 2011 | 09:38 AM
Jay10Ralliart's Avatar
FCOTM Winner
from what Ive heard we don't need a boost controller
Old Jan 14, 2011 | 09:45 AM
jkennedy293's Avatar
Most of us use a boost pill. It seems to work the best with the SST.
Old Jan 14, 2011 | 10:44 AM
zx-319's Avatar
You don't need a boost controller, the ECU controls boost on our car. All you would need is a boost pill to assist you in better tuning your boost.
Old Jan 14, 2011 | 02:31 PM
elmerfud54's Avatar
well ive got a boost pill, i figured having a boost controller would allow you to better control the boost
Old Jan 14, 2011 | 02:38 PM
majinfajita's Avatar
I think more succinctly put is that instead of using a boost controller, it is better to use the boost pill in combination with an ecu tune (several benefits being tuning the variable valve timing/MIVEC to aid with spooling up the turbo, fueling, etc).
Using a boost controller, or piggyback ecu, to tune your boost is more of a thing of the past (for mild setups) due to the increased tuneability and reliability from an ecu tune. Wilder setups may still be better served by a (high end) boost controller or piggyback setup, but it is not the preferred or better method for milder setups...and even then, there's guys running FP Reds (or bigger!) using ecu tunes and not having to go to a standalone/piggyback solution.
Old Jan 14, 2011 | 08:00 PM
Piper747's Avatar
If you want even more control of your boost, you can get a 3-port boost control solenoid. Requires a different tune though, of course, than the pill.
