Q? What specifically has failed with RA transmissions?
Old Apr 13, 2011 | 07:08 AM
chlucero's Avatar
I know that the clutch is a little weak and a point of failure; but what other failures have occurred with the RA/MR transmissions?
Old Apr 13, 2011 | 07:26 AM
jkennedy293's Avatar
I've seen posts related to solenoids, leaky filter housings, and temp sensors.
Old Apr 13, 2011 | 07:44 PM
El-Diablo's Avatar
RA failures
There is a dealer notice regarding Cracked filter housings. this should be inspected and if found changed on service. Make sure your dealer checks it (this is a production fault either related to the casting or overtorue during assembly)
Most posts I have seen are around Clutch Failures however metallic debri from clutch plates could cause premature wear on gear teeth as has been experienced by a number of tuning houses which could ultimatley lead to stripping of teeth.
