Ultimate Racing Turboback Exhaust Tune?
I talked to UR about their turboback exhaust and they said that if i got the HFC that the car wouldn't require a tune for the exhaust. I always thought that when you change out the DP and cat you would need a tune. What do you guys think?
To get the most out of the upgrade, you need a tune. But I don't think its required. I'm looking to do the same setup and I'll be running the same turboback exhaust for a while until I get the money to get a Cobb AP and use their stage 2 tune.
Stage 2 Cobb is catback, highflow cat, and downpipe. Any additional mods will mess up the tune. Just a heads up. I'm running a Evo X FMIC with my Stage 2 and there's noticeable lag.
"Stage2 for vehicles with a turbo-back exhaust system. 93 or 94 Octane fuel. +26% HP / +30.3% lb. ft." <----right from cobb website
I am running the UR turbo back and for one it sounds awesome. Definitely love the sound and performance over stock and the magnaflow catback I had. You would need to get a tune though for it. Would it be fine? Sure you could run with it like that, but you aren't going to get the full power from it. If you have a wideband then you could watch your before and after numbers and that would give you an idea of how it is affecting your car.
Main thing is to keep an eye on boost. Depending on what map you are running and how the boost control is setup... you may end up fighting with error correction as it is going to want to spike up higher than before with the freer exhaust.
Well Im going to go back to my stock map so im gonna be getting around 18psi?
I just want to get the turboback cause it sounds sick and i would rather save up month for a tune then wait for it all together
Just saw your running the gst base map... with or without pill? Without pill I think your fine to leave the base map in there. it's gonna be slow as bawls without it, even with the exhaust. If it were me I would try to get hold of a tactrix cable and laptop to take Bryan up on his offer to do a base map for turbo back exhaust.
