Variable Cam Timing?
Old Feb 1, 2012 | 09:02 PM
RalliAaron's Avatar
I looked around and searched the forums, and found someone else that had the same problem as me.
I "clunking" noise that sounded like an engine knock coming from the valvetrain area, which turned out to be a cracked cam in his case, but in mine, I was old that its my VCT, or Variable Cam Timing.
Ive searched around and can find no information on this, so I was wondering if one of the Mitsu Guru's here could help out?
Old Feb 1, 2012 | 09:42 PM
sstevojr's Avatar
Its Continuously Variable Timing, aka MIVEC.
Your cam shaft cracked? Odd, maybe oil starvation?
Old Feb 1, 2012 | 09:56 PM
RalliAaron's Avatar
No, my cams are fine, I was told the timing is off, so its causing a deeper "tick" behind my injectors. It almost sound like an engine knock.
Old Feb 1, 2012 | 10:16 PM
sstevojr's Avatar
???What shop is this? Take a vid, as the engine bay has numerous ticking sounds that are all completely normal. Might just be the lifters ticking away
If the timing chain was stretched the car has a warning system for that. If you installed aftermarket cams it is possible to install them out of sync (by a tooth or two) and they would still run, but not very well.
Old Feb 2, 2012 | 06:14 AM
RalliAaron's Avatar
Ill take a video of it after work, and I have stock scams. The place is called Engine Rebuilders, and they said the can timing is off, but he may mean valve timing. This shop isn't a Mitsu place, so he may not know exactly what its called, but he said for sure its the Timing adjustment?
Old Feb 2, 2012 | 06:27 AM
03chi-town0Z's Avatar
Go somewhere else
Old Feb 2, 2012 | 08:20 AM
RalliAaron's Avatar
Originally Posted by 03chi-town0Z
Go somewhere else
I wish it were that easy, the dealership actually sent my car here, they said they use this place alot. I'm not sure what to believe?
Old Feb 2, 2012 | 03:22 PM
Wow, that's awful. Try and get a video posted then, I guess. Otherwise you could always take a road trip over to SSP
