New Unknown DTC Code P34A0
Old Feb 4, 2012 | 03:47 AM
caribou68's Avatar
Hello,
this morning I had the orange light in the Dashboard I think it is the check engine light of my 2010 Mitsubishi lancer ralliart 100% fullstock with 54 000 km...
I used EVOSCAN 2.9 with my tactrix openport 2.0 cable to find the code and it displays :
Updated: 12:10:36
Initializing CAN...
Checking for EVOX EFI Diagnostic Codes...
Correct Header byte response returned.
1 Current Diagnostic Trouble Codes Found...
P34A0
I tried to clear all dtc but it stays...
I tried to find in all the documentation and internet and there is nothing for this code...
do you think it is the wrond code or do you have an idea how to diagnose where does it come from ? Should I go to the dealer ?
Thanks in advance for your help.
Best regards,
Clément
Old Mar 4, 2012 | 05:43 PM
AWDralliart09's Avatar
I just got the same code on my car? I have no clue either to the cause or what the code even means, but on my evoscan the code came up as C31B8.
Sorry I can't be of any help but I do share your concern.
Old Mar 4, 2012 | 07:05 PM
omegis's Avatar
Use ECUFlash instead to clear your DTC
Think there are some gremlins in EvoScan 2.9
Old Mar 6, 2012 | 01:55 PM
Ok so I've cleared this DTC twice now, from evoscan and ecuflash.. I can only see the actual DTC from evoscan, cant figure out how to see the codes in ecuflash... Just the option to clear them.
Does anyone have any idea what this DTC means.. This same issue as for the "correct header byte response returned" but sometimes gives me a different code.. P34E0, C31B8
Old Mar 6, 2012 | 02:32 PM
RazorLab's Avatar
You can also try this:
Old Mar 6, 2012 | 04:32 PM
richardjh's Avatar
Ha! That brings back memories! I had a wire fitted to my old FTO's OBD port that could ground a certain pin - for flashing check-engine-light DTCs at me in morse code.
Glad to see that system is still there somewhere, locked away in our ROMs... just a bit more civilised.
Rich
Old Mar 6, 2012 | 04:52 PM
sstevojr's Avatar
morse code....classic!
c h a n g e f l u i d.s t o p. c l u t c h s l i p p i n g.s t o p
Old Mar 14, 2012 | 12:10 PM
chetrickerman's Avatar
Veteran: Army
Anyone know what P34E0 is?
Old Apr 5, 2012 | 09:14 AM
I keep getting the same thing too. Not all the time, its intermittent. But sometimes it comes up as P34B0 , P34A0 depending on the ecu selection.
I have yet to make it to a dealership and have it hooked up. I hate having someone troubleshoot my stuff..
Let us know if you find something.
Old Apr 9, 2012 | 10:44 AM
Going to dealership today to find out what this code is...
Old Apr 9, 2012 | 10:57 AM
RazorLab's Avatar
Everyone needs to STOP using Evoscan v2.9 for DTC's
It's broken. DO NOT USE IT.
Old Apr 9, 2012 | 02:44 PM
omegis's Avatar
^ this is very true but don't be surprised if another thread starts
Old Apr 9, 2012 | 04:27 PM
Yup I agree. So at the dealership, they said my car is throwing a P0139. But my rom has the disable for that code?. Or at least I thought it does.
Old Apr 9, 2012 | 04:34 PM
RazorLab's Avatar
The 2009's do it different then the 2010+
Old Apr 9, 2012 | 04:45 PM
bossssman38's Avatar
I'm having a hard time understanding how to read codes with the cruise light. How do you get 10 digits from two long flashes? And you just count the number of time it flashes?
