cluncking underneath the car
Old Sep 23, 2013 | 01:28 PM
jangempo's Avatar
once in a while when I come to a complete stop with '10 ra I hear a clucking noise coming from under the car, closer to the back. What is that and is it someting to be worried about?
Old Sep 23, 2013 | 05:54 PM
Firebuck2059's Avatar
Sub'd for an answer as I sometimes have a sound like this as well.
Old Sep 24, 2013 | 12:01 PM
Veronica's Avatar
uh... I would recommend you have another person drive it and stop in front of you (once you can understand the circumstances and can replicate them to makes the sound).
Then you have at least left rear/right rear or center place to start looking (and shaking parts).
I assume you already checked the obvious stuff - the loose stuff in the trunk and then inspected the spare tire well for loose stuff...
Old Sep 26, 2013 | 09:56 PM
jangempo's Avatar
I'm pretty sure it's got something to do with the brakes. It doesn't happen all the time, it seems to be more common when coming to a quick stop. I'm gonna take it in for my peace-of-mind inspection and mention it to them.
Old Sep 27, 2013 | 07:12 AM
Evo Sportback's Avatar
I gonna guess it could be warped rotors, or some bad rear struts?
Old Sep 27, 2013 | 07:49 AM
Veronica's Avatar
^warped rotors won't 'clunk' - they shimmy the steering wheel and/or make a pulsing feel in the brake pedal.
Old Sep 29, 2013 | 03:23 PM
parralegend's Avatar
I have that similar open clunk noise and yes I think its related to the brakes. I had a thought that it might be hydraulics related to the diff but that's a random guess .
I also get a similar noise if I'm in 6th (sports mode) cruising and I take my foot off the accelerator where in normal mode it wont make the noise which I assume is clutch pressure.
Old Oct 21, 2013 | 10:12 PM
dickynee's Avatar
I have the same noise but I don't think it's brakes, I think it's more to do with the drivetrain or transmission coz it happens in 6th when I'm coasting and when I stop or sometimes go to take off. It's sound to me like it's the transmission disengaging and then re-engaging
Old Oct 22, 2013 | 03:33 AM
GingerBear's Avatar
If I'm not mistaken the SST disengages when you come to a stop. I'm pretty sure you're referring to the same noise I'm accustomed to occasionally hearing, and I believe it's the transmission. The sound reminds me of a loose control arm.
Old Oct 22, 2013 | 04:09 AM
jangempo's Avatar
The more I hear it the less I think it has to do with my brakes. I try to coast to a stop most times, using as little brake pressure as possible and I still get the noise. It sometimes doesn't occur until a few seconds after being completely stopped.
CottageLifer
Outlander Sport
Oct 7, 2016 05:10 PM
erikerwin
Lancer Engine Tech
Nov 26, 2010 07:08 PM
mine's evo
Mar 15, 2008 10:24 PM
bud_thoj
Mar 20, 2007 06:41 PM
cky3396
15
Jan 23, 2005 11:05 AM
