Is this 'slippage' while shifting?
Old Feb 8, 2014 | 06:57 PM
root@localhost's Avatar
If I go WOT from a dead stop while in sport manual mode, there's always a huge delay from the time I shift to the car actually shifting.
I can feel the car beginning to shift, and for a brief moment my rpm is climbing rather quickly ( example I shift at 6500, the rpms rise to 7500 then shift)
I dont know if this has always been the case, or im only noticing it after having the borla installed.
It feels like the car completely loses power for a brief moment while this is happening and i can hear "pop pop pop" coming from the exhaust.
Is this normal or the signs of a problem starting to develop?
Notes: Car is completely stock, save the borla cat back and a K&N drop in.
Issue is only in Sport manual
Old Feb 9, 2014 | 08:49 AM
Slee256's Avatar
Did you get rid of the stock cat when you installed the Borla "cat back" exhaust? If so, you really shouldn't be driving that car without a new tune. If you still have the stock cat then you can stick with the factory tune, but these cars weren't designed to run a high flow cat or test pipe using the OEM tune.
Old Feb 9, 2014 | 10:40 AM
neogeo64's Avatar
I'm pretty sure he still has factory cat if he only installed a "cat back".
I would do a fluid flush on the SST if it's been a while.
IC_EVO
Mitsubishi TC-SST Discussion
21
Dec 30, 2016 08:55 PM
jbrennen
Dec 22, 2014 10:56 AM
parralegend
Feb 16, 2014 06:27 PM
waterlooLancer
26
May 17, 2012 08:55 AM
mitlan
Dec 3, 2011 08:08 PM
