dom 2.0 ralliart dyno results inside
Old Aug 9, 2011, 08:57 PM
hixlancer's Avatar
Ok so here are the results to my tuning at Modified by KC. Mods on the car are Dom 2.0 turbo, complete evo x swap, 3" TBE, DW 800cc injectors, GrimmSpeed 3 port EBCS, Boost pill removed, K&N Cone filter. It was about 94 degrees on 91 octane. What do you guys think?
Old Aug 9, 2011, 09:03 PM
vicq's Avatar
no too bad cant wait till i do my x swap, right now on stock turbo 321hp 360tq so i wonder what i will be at after!!!
Old Aug 9, 2011, 10:08 PM
MitsuG24's Avatar
That's dope dude. By chance where did you get your Dom from?
Old Aug 9, 2011, 10:27 PM
hixlancer's Avatar
Bought it from the guy who bought an evo from buschur racing
Old Aug 9, 2011, 10:29 PM
hixlancer's Avatar
Ill add that the guys at modified by kc are great people it was a good experience
Old Aug 10, 2011, 06:47 AM
Mad_SB's Avatar
hmm, I don't know anything about that dynojet but those numbers seem low for a DOM2... were the baseline / blue plots stock RA or tuned? I assume tuned?
Old Aug 10, 2011, 06:59 AM
hixlancer's Avatar
They are low? Yeah I was hoping to hit at least 350 but came short. The blue is the ra turbo with cba and gst maps.
Old Aug 10, 2011, 10:14 AM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
Yea it seems a bit low. I made almost 320whp on 91 oct on my BBX Lite with stock catback, on a proper mustang dyno. 24.5psi across.
The boost plot you posted looks a bit wack.
Old Aug 10, 2011, 10:28 AM
hixlancer's Avatar
could the boost plot be whack because I'm not running a boost pill anymore?
Old Aug 10, 2011, 12:03 PM
sstevojr's Avatar
Just the opposite, a 3-port will maintain better boost stability than the pill.
Looks like there is a struggle with the boost from 5500 on ward. There is a known dip at 5500, but it shouldn't last more than a couple hundred RPM's. It seems to carry all the way to 7000?? Maybe take a look at the WGDC and/or error correction?
EDIT: actually it could be a lot of things. what is the psi on the actuator? If its really low then even giving it 100% WGDC don't do much to help that drop off. I don't know a whole lot about the DOM's, but it looks to be having issues breathing from 5500-7000?
Old Aug 10, 2011, 12:55 PM
hixlancer's Avatar
Its got the buschur racing wga...so should be good....
Old Aug 10, 2011, 01:22 PM
Bom's Evo's Avatar
Are you on stock intercooler and pipes?
Old Aug 10, 2011, 01:38 PM
hixlancer's Avatar
Ive got the x ic and pipes
Old Aug 10, 2011, 02:01 PM
RazorLab's Avatar
It's not an issue with the DOM 2 breathing. It's a capable turbo. I've tuned a DOM 2 Evo 10 GSR to 450whp / 360wtq on E85 on a proper Mustang dyno.
On a MR, I tuned a DOM 2.0 to 370whp / 290wtq on 91 octane, with cams, on the same Mustang dyno.
Old Aug 10, 2011, 02:14 PM
hixlancer's Avatar
Very nice bryan...im not sure what the problem is
Quick Reply: dom 2.0 ralliart dyno results inside
