RAX v3 w/ TephraMOD v3
Old Feb 11, 2019 | 03:59 PM
hixlancer's Avatar
Veteran: Army
Exclamation RAX v3 w/ TephraMOD v3
I'm trying to install the RAX V3 patch and use that with TephraMOD v3. So my TephraMOD ROM is Tephra - 53600310, on that rom ROMID: 53600010 is included, on 53600010 ROMID: 53600008 is included, and on that ROM evo10base is included. The RAX patch will not work unless I put it into the evo10base ROM, and I have not tested it out on the vehicle yet. I am wondering if this is the correct way to do it? The RAX patch that's for my vehicle is the 53600009... I've tried to put it into that rom (53600009) but that did not work. I tried it individually on 5360010 and 5360008 and it did not work...when i pasted into evo10base it shows up in Ecuflash. I tried following the directions to no avail. (ie: pasting into ROMID 53600009...Can someone please tell me if pasting the included portion (<include>RAX53600009</include>) is the correct way to install the RAX patch?
To make a long story short. RAX patch options only display when I paste into evo10base, and not all the other XML that are inherited by 53600010. I am lost.
Edit: If I figure this out before I get some replies I will do a write up on how to get this to work when your using Tephra v3 that inherits stuff from other XML. In my case it is inheriting from 53600010, which inherits from 53600008, which inherits from evo10base...im pulling my hair out right now.
Old Jul 17, 2019 | 05:56 AM
night crawler's Avatar
i would like an answer to that as well
