3 sec start then stall
2011 Ralliart with cobb stage 2 ots map + supporting mods.
Maybe someone here has dealt with this or knows of someone who has; my RA refuses to run longer then 3 seconds before completely stalling out. If i give it gas itll register within the 3 seconds then proceed to die out. Doesn't matter how many times you try it the outcome is the same; Normal cold start for 3 sec then dies. The only way im able to keep it running is if i unplug the MAF and itll cold start around 800-1000rpm until shes warm then it slowly climbs and holds at around 1500rpm. Theres absolutely no codes stored or pending except for the MAF code(obviously from being unplugged). Ive tried replacing MAF, air filter, spark plugs, and the map sensor all which lead in absolute no difference to the 3 second run time. If anyone has ANY idea or something i could try im all ears. The RA has been down 3 weeks and im running out of ideas.
