COBB AccessPORT for 2009 Mitsubishi Lancer Ralliart Now Available!
COBB Tuning announces the immediate availability of theAccessPORT for the 2009 Mitsubishi Lancer Ralliart . The AccessPORT is the first hand-held device available for the Ralliart that performs an ECU reflash through the vehicle’s OBDII port. Just plug it in, load a map and go! Faster! The AccessPORT provides owners of 2009 Mitsubishi Lancer Ralliart vehicles the ability to unlock power hidden within the factory ECU. Performance gains across the entire powerband can be quickly realized in the short time it takes to flash the vehicle’s ECU with the AccessPORT. No tools are required. No additional “piggy-back” hardware. No mailing the factory ECU across the country. No vehicle downtime. No waiting. Not even a computer is required. Just plug the AccessPORT in, flash the ECU and enjoy the thrill of increased torque and horsepower! Flashing the ECU for increased performance is just the start of what the AccessPORT is capable of. Set the AccessPORT to Performance mode to capture 0-60MPH times, ¼ Mile times and Trap Speeds. Switch over to Live Data and choose a gauge to monitor, such as; coolant temperature, intake air temperature, throttle position, intake cam advance, exhaust cam retard, MAF voltage, injector pulse width and many more. Select the integrated Datalogger to record multiple channels of data simultaneously. Or configure a shift light that flashes the screen when a user defined rpm is reached. Go to Troubleshooting mode to diagnose issues by reading the factory codes and resetting the system once the issues have been resolved. The AccessPORT can be used to eliminate separation anxiety for those times you are away from your car. Protect your investment when out on the town by quickly loading the Valet map to prevent the engine from revving above 3,200 rpm. Load the Anti-Theft map when you park to make it impossible to start. And in the event the car must be returned to the stock configuration, the AccessPORT can be completely removed and the ECU restored to its factory condition. AcessTUNER Pro tuning software for the Ralliart is available to the COBB Pro Tuner network. AccessTUNER Pro allows professional engine tuners to custom tune any combination of modifications to achieve their maximum power potential. AccessTUNER Race tuning software for the Ralliart is available to racing teams and highly experienced self tuners. AccessTUNER Race allows individuals the ability to tweak their own maps files at their convenience as well as the ability share maps with others that have very similar power modifications. Datalogging allows multiple channels of data to be recorded and reviewed after a dynamometer test to see where tuning can be optimized. Disabling torque and airflow limit tables makes tuning the Ralliart even easier. These capabilities are particularly effective for heavily modified Ralliart’s that are beyond the scope of the COBB Tuning provided base calibrations. The AccessPORT from COBB Tuning is the most comprehensive hand-held ECU flashing, monitoring and managing device available for the 2009 Mitsubishi Lancer Ralliart. Combined with AccessTUNER Pro and AccessTUNER Race software, it provides an unbeatable suite of engine tuning applications backed by our professional engine tuner network. Satisfy your hunger for more power. Access the Potential of your Ralliart today! |
You just made a lot of RA owners happy :D
Now we need some supported mods... |
Wooooooooooooooooooooooooooohooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooo!!!!{thumbup}{thumbup}{thumbup}{thumbup}{thumbup}{thum bup}{thumbup}{thumbup}{thumbup}Finally!
That's f'n amazing to say the least. +2 on the stage 2,3
I know what I want to save up for now.
WOOOooooOOO!!!!!! {thumbup}{thumbup}{thumbup}{thumbup}{thumbup} |
Originally Posted by detroitra
(Post 7902883)
i know what i want to save up for now.
woooooooooo!!!!!! {thumbup}{thumbup}{thumbup}{thumbup}{thumbup} |
I park my car in downtown Detroit every other day, for 8-10 hours while I'm at work. So having an anti-theft map would be freaking awesome. Put my mind at ease while I'm at work.
Any plans for stage 2/3 maps in the future? |
HOLY MUTHA F'A :thumbup:
you just made my day. i had to do a double take when i saw the thread. |
valet map will be very nice
Are those dyno #'s on a 100% bone stock RA? Or does it have an intake/exhaust?
How does this tune effect the addition of an intake? |
has anyone found a price yet??
my buddy gets his speed6 worked on at the cobb here and he just texted me on this. i may have to run by next time he's up there and check this out. I'm still debating on modding the RA or trading it for a X. If I decide to keep the RA I'll be getting this.
Originally Posted by hotshot1
(Post 7903274)
Cobbs site state that this is for a STOCK RA and I would presume any modifications would require the Tuners software which is available for $1500.00 Yikes! Im not sure if this would work with a FMIC , UICP or/and a test pipe,or a TBE. :shocked: Doing more research but I don't see this as the Holy Grail for RA it does seem like a viable option from e-mail ecu flashes. Found this: Stage1 ACN91 RAv100 - Intended for an otherwise stock 2009 Mitsubishi Lancer Ralliart vehicle with a stock or cat-back exhaust, and STOCK INTAKE SYSTEM. Arizona, California, and Nevada 91 octane fuel. Boost Targets: ~16psi peak boost pressure tapering down to ~11 psi by the 7500 RPM redline, +/- 1.5psi. |
Originally Posted by CaSilvia
(Post 7903226)
looks stock from what this says. 3 stage 1 maps stock http://www.accessecu.com/accessport/...ancerMaps.html read the map notes they will put out maps for stage2 later i'm sure |
Ask and you shall recieve:).
http://www.cobbtuning.com/products/?id=5027 |
