-   09+ Ralliart Engine/Turbo/Drivetrain (https://www.evolutionm.net/forums/09-ralliart-engine-turbo-drivetrain-309/)
-   -   12's on stock turbo running E-85! (https://www.evolutionm.net/forums/09-ralliart-engine-turbo-drivetrain/482792-12s-stock-turbo-running-e-85-a.html)
Fourdoor Mar 27, 2010 03:34 PM
2 Attachment(s)
Well guys,
Only change from my first 12 second time slip from last year is that this one was on E-85 instead of 93 octane, and EVO VIII MR wheels with Advan tires instead of Enkies with Blizzaks.
The stock fuel system can only handle a few seconds at high boost / heavy load before I go lean. Running through the gears, boost falls off fast enough that this isn't a problem until I get into 5th gear. After 3 seconds in 5th gear at over 21 psi of boost (and over 100% duty cycle on stock injectors) I start to go lean and have to let off the throttle.
Even with this issue I was able to pull a 12.916 @ 102.81 I was planning to crank up the boost higher, and advance the timing... but with this issue I saw no reason to push any harder on the stock fuel system.
Here is the time slip:
https://www.evolutionm.net/forums/at...stock-turbo-ru
Keith
secondchace Mar 27, 2010 03:53 PM
new fuel pump > new injectors.
good time though :)
Fourdoor Mar 27, 2010 04:00 PM
good time though :)
Thanks!
I am getting upgraded cams, ported intake manifold, and the double pumper fuel system with 1000 cc injectors in the next week or so installed and tuned by Buschur Racing on E-85... just waiting for the cams to come in :)
Keith
GiLizILL Mar 27, 2010 04:07 PM
was expecting a higher trap with e85, none the less. good job
Fourdoor Mar 27, 2010 04:13 PM
Second slip has my best mph (104.4) and keep in mind I am letting off the throttle in 5th gear before the end of the track due to going lean from needing the fuel system upgrades.
Keith
GST Motorsports Mar 27, 2010 08:49 PM
Nice congrats on the time Keith.
btw, picked up the sportback today. ;)
- Bryan
Fourdoor Mar 28, 2010 12:08 AM
- Bryan
What color did you get? What options? What ROM ID? :)
Keith
GST Motorsports Mar 28, 2010 12:11 AM
Keith
White with Recaro package.
Haven't pulled the ROM yet. It's on the to-do list for tomorrow. :)
- Bryan
laksman91 Mar 28, 2010 12:11 AM
Awesome times! did you do a complete tune overhaul with the E85?
- Bryan
congrats Bryan on the acquisition
Fourdoor Mar 28, 2010 03:21 PM
Nope. Due to the need for larger injectors and fuel system upgrade I chose not to do a new custom tune for the car. Just re-scaling the injectors got me to the point where the car is fine for daily driving and even "spirited" driving as long as it doesn't involve a long pull in a single gear resulting in leaning out the engine... so I will leave it as is until I pun in the fuel system, cams, and ported intake manifold.
Keith
Ladogaboy Mar 28, 2010 06:34 PM
Nice time!
So, do we know for sure that the RA fuel injectors are smaller than the EVO's? Any idea of the cc's for the stock RA injectors?
orange_rally Mar 28, 2010 07:18 PM
nice run i just pull out a 12.95 @104 mph on stock tires with 93 oct tune at 22 psi and im running rich a lot so no problem here with the injectors!!! so i can expect going lower than that next week with fine tunning here my slip with a pic of my car
http://photos-a.ak.fbcdn.net/hphotos..._6633090_n.jpg
http://photos-e.ak.fbcdn.net/hphotos..._5754835_n.jpg
http://photos-g.ak.fbcdn.net/hphotos..._6837764_n.jpg
athmak15 Mar 29, 2010 12:01 PM
Very nice. Injectors and fuel pump and you'll be golden!
tre Mar 29, 2010 07:48 PM
nice runs!
don't mean to hijack. but orangerally what mods do you have done?
orange_rally Mar 29, 2010 07:53 PM
UR turbo back, UR intake, UR hardpipes (uicp and licp), AMS boost pill and tweaked ecuflash with 7-8 hours of testing but still runnin very rich so might be able to get better but @ 26 psi was doin 13.2 and now im doing 22 psi and runnin better i played with the timing and the mivec with a 93 oct tune
