12's on stock turbo running E-85!
Old Mar 27, 2010 | 03:34 PM
Fourdoor's Avatar
Well guys,
Only change from my first 12 second time slip from last year is that this one was on E-85 instead of 93 octane, and EVO VIII MR wheels with Advan tires instead of Enkies with Blizzaks.
The stock fuel system can only handle a few seconds at high boost / heavy load before I go lean. Running through the gears, boost falls off fast enough that this isn't a problem until I get into 5th gear. After 3 seconds in 5th gear at over 21 psi of boost (and over 100% duty cycle on stock injectors) I start to go lean and have to let off the throttle.
Even with this issue I was able to pull a 12.916 @ 102.81 I was planning to crank up the boost higher, and advance the timing... but with this issue I saw no reason to push any harder on the stock fuel system.
Here is the time slip:
Keith
Attached Thumbnails 12's on stock turbo running E-85!-new-slip.jpg   12's on stock turbo running E-85!-best-mph.jpg
Old Mar 27, 2010 | 03:53 PM
secondchace's Avatar
new fuel pump > new injectors.
good time though
Old Mar 27, 2010 | 04:00 PM
Fourdoor's Avatar
good time though
Thanks!
I am getting upgraded cams, ported intake manifold, and the double pumper fuel system with 1000 cc injectors in the next week or so installed and tuned by Buschur Racing on E-85... just waiting for the cams to come in
Keith
Old Mar 27, 2010 | 04:07 PM
GiLizILL's Avatar
was expecting a higher trap with e85, none the less. good job
Old Mar 27, 2010 | 04:13 PM
Fourdoor's Avatar
Second slip has my best mph (104.4) and keep in mind I am letting off the throttle in 5th gear before the end of the track due to going lean from needing the fuel system upgrades.
Keith
Old Mar 27, 2010 | 08:49 PM
GST Motorsports's Avatar
Nice congrats on the time Keith.
btw, picked up the sportback today.
- Bryan
Old Mar 28, 2010 | 12:08 AM
Fourdoor's Avatar
- Bryan
What color did you get? What options? What ROM ID?
Keith
Old Mar 28, 2010 | 12:11 AM
Keith
White with Recaro package.
Haven't pulled the ROM yet. It's on the to-do list for tomorrow.
- Bryan
laksman91's Avatar
Awesome times! did you do a complete tune overhaul with the E85?
- Bryan
congrats Bryan on the acquisition
Old Mar 28, 2010 | 03:21 PM
Fourdoor's Avatar
Nope. Due to the need for larger injectors and fuel system upgrade I chose not to do a new custom tune for the car. Just re-scaling the injectors got me to the point where the car is fine for daily driving and even "spirited" driving as long as it doesn't involve a long pull in a single gear resulting in leaning out the engine... so I will leave it as is until I pun in the fuel system, cams, and ported intake manifold.
Keith
Old Mar 28, 2010 | 06:34 PM
Ladogaboy's Avatar
Nice time!
So, do we know for sure that the RA fuel injectors are smaller than the EVO's? Any idea of the cc's for the stock RA injectors?
Old Mar 28, 2010 | 07:18 PM
orange_rally's Avatar
nice run i just pull out a 12.95 @104 mph on stock tires with 93 oct tune at 22 psi and im running rich a lot so no problem here with the injectors!!! so i can expect going lower than that next week with fine tunning here my slip with a pic of my car
Old Mar 29, 2010 | 12:01 PM
athmak15's Avatar
Very nice. Injectors and fuel pump and you'll be golden!
Old Mar 29, 2010 | 07:48 PM
tre's Avatar
tre
nice runs!
don't mean to hijack. but orangerally what mods do you have done?
Old Mar 29, 2010 | 07:53 PM
UR turbo back, UR intake, UR hardpipes (uicp and licp), AMS boost pill and tweaked ecuflash with 7-8 hours of testing but still runnin very rich so might be able to get better but @ 26 psi was doin 13.2 and now im doing 22 psi and runnin better i played with the timing and the mivec with a 93 oct tune
