AMS Ralliart Modification Stages 0-3
As it says in the title, AMS has obviously been working hard on providing the best performance upgrades for us. They have now come out with Stages 0-3 for the Ralliart. WOOOOOOT I am so stoked!!
http://www.amsperformance.com/cart/a...rt-stages.html |
o **** I am going to have over 300 here soon then I cant wait....
a stage 1 can get 305hp with just an intake, cb exhaust and a flash?
OK so if I want stage 3 do I have to get 1 and 2 First? Im new RA owner so you vets square me away.
Originally Posted by jan_ralliart
(Post 8201944)
its about time :D, good job AMS.......
Originally Posted by jscout21
(Post 8202031)
Originally Posted by jkennedy293
(Post 8202048)
Those figures are based on crank hp and torque, not the wheel hp and torque readings you get from a dyno.
1 hour of dynotuning: $250.00 Rear axel-back exhaust: $375.00 UICP: $140.00 Boost pill: $ 20.00 ---------------- Grand total: $785.00 |
I want stage 3!
I'm getting the fmic kit. Licp. And test pipe soon and a custom tune. Man I can't wait. I will post my numbers up in a new thread.
FMIC is a pita to install, makes the front look BA though. If you know someone who will help it'd make the job easier. The hardest part (only real challenge) is getting it behind the crash bar on the rubber supports aligned properly, and getting the bolts in. It took me and my best friend a few hours. I need mine repainted, all the salt took the AMS almost completely off of it.
The stage 3 is expensive. You can get a bigger turbo or used X turbo, widemouth DP and a tune for a lot less than that.
edit. Does the stage 3 include an Evo X exhaust manifold? It doesn't say that it's part of the kit. |
Originally Posted by athmak15
(Post 8203849)
the power numbers are to the crank i hope you kids realize that
secondly, the stage 3 doesnt specify if it has the manifold, oil lines, and other parts required. |
Originally Posted by secondchace
(Post 8204850)
