ACD Pump same as Evo IX??
Does anyone know if the our pumps are same as EVO IX? I spoke to someone before and they said the guts and most of its same but not sure if its direct swap. If its a straight swap then I can easily get my hands a low mileage evo ix pump cheap.
No pumps are not same , what exactly do you need to know
My pump is dead, i came across a IX pump just wondering if it would work since it was cheap. Im trying to find a solution but dont have $600 to spend on rebuild right now
The pump in my car has been dead for over a year now (no desire to fix), you can drive with it inop still. You'll just lose the nifty center diff locking, the drivetrain will be somewhat similar to a 4x4 truck. :lol:.
Get frugal, and save up money to get it rebuilt or replaced correctly. I don't believe one from the VIII/IX will fit correctly, however an X pump should be a direct swap. |
Can't swap Evo x to Ralliart either.
Originally Posted by DetroitRA
(Post 10804151)
Originally Posted by Ruff-Shaw
(Post 10804433)
Plug up the AYC ports and rewire the rest? Sounds like it might work to me.
It'd probably be cheapest, or most effective, to have acd-tuning rebuild the ACD pump in any case. I believe that they use better material that's less likely to corrode. |
1 Attachment(s)
Originally Posted by 03chi-town0Z
(Post 10805065)
I know they're not the same part, but I'm curious if this is actually the case because the castings look the same, but the second set of ports is just not drilled through on the RA pump. I've been wondering if you could just install some generic plugs on the unused ports and rewire the connectors...
^03chi is talking about trying to retrofit an X pump.
Did you try both the IX and X pumps? Or just the IX? |
(Post 10805818)
More availability in used part market from people removing pumps for race applications and the overall higher number of X's produced vs RalliArt
(Post 10805922)
