How to raise the Stock Recaro seat.
What's to try? All you're doing is adding a spacer. Just use a spacer with an inner diameter that matches the bolt's diameter, and you should be fine unless the spacer is tall enough to prevent the bolt from threading properly.
I guess shearing may be a concern, but if you're serious, you could get it welded as mentioned.
Ya shearing would be a concern, as I probably wouldn't weld them. I realize that people will not provide examples, as I'm sure the ones who have done it have not been in accidents. In addition, I guess I'm wondering how much you notice the difference after applying the spacers.
If I was to do something like that, I would take a solid and large enough piece of metal and drill it... I wouldn't use washers! And using a larger bolt would a good idea juste to compensate the extra lengthl...
This is the kind of setup that could get your insurances to refuse to cover your injuries in case of accident...
+1
Also, unless the seat belts are attached to the seat itself (which is NOT the case, they are bolted to the side of the car and the floor), the belt would keep you and the seat from going forward in a crash.
I'm not sure I see what the issue is...this setup would be at least the same strength as when it was lower? He's not using washers to increase the height..it's a longer bolt.
Also, if you didn't realise it, the seat belt is holding against the seat. If the bolts attaching the seat to the floor break, the seat WILL move back (you'll be pushed back by the air bags) thus render the seat belt totally useless and even potentially dangerous. Frontal collision is not the only type of accident you can get in.
And you don't only need a longer bolt but also a larger one. The longer the bolt is, the higher the stress you put on it.
Didn't realize the seatbelt was attached to the seat. In my GTI, it's actually seperate from the seat brackets and is bolted into the floor.
I'm looking into getting a RA sportback and I've read about this seat height issue being a problem, so just want to make sure there is a solution.
Have you ever seen what a seat from one of these cars looks like in a crash............
go to a local junk jard. the seat flattens its self to the floor.
Those little spacer and bolts will only promote the seat in crushing you.
NEWB
