Need help Installing Wideband AFR
Old Mar 1, 2010 | 06:26 PM
rallifreek's Avatar
I just got the Glow Shift Wideband AFR and need some help on where to put the BOSCH sensor. Can i remove one of the O2 sensors and put this one in place or is that goin to be givin me and Engin code. I dont mind if it needs welding i can do that just need to know if there is an easy way. Any help is appreciated.
Old Mar 1, 2010 | 06:40 PM
cmrs2k's Avatar
You can weld a new bung in place (ahead of the catalytic converter) and have the wideband operate completely on its own. The other option is to install the wideband in the place of the narrowband o2 sensor before the catalytic converter. This is the more complex option as there will be at least a couple of additional issues to deal with. The smartest way to go (IMO) is to go with the first option.
Old Mar 1, 2010 | 06:41 PM
athmak15's Avatar
If you remove your 02 sensors you will throw a CEL. Get a bung welded on your downpipe and run the wideband sensor through the grommet where the front 02 sensor goes.
Old Mar 1, 2010 | 07:36 PM
rallifreek's Avatar
cool thanks i guess ill be doin some welding this weekend
90zcrex
Dec 16, 2012 09:10 AM
XTR Performance
Evo 'For Sale' Interior Styling
84
Dec 14, 2012 09:59 PM
Mervin
May 7, 2011 04:56 AM
evo821
Jul 30, 2009 10:34 AM
SwiftEVO
17
Jun 22, 2005 11:20 AM
