Car won't start
Can someone please help me! My ride will not start..everything is working fine in the ride lights,radio,power all fuses are good & Spark plugs.. I have a Cobb tuning and have checked codes. Has anyone else received this code
ECU U0i67 Immobilizer communication error |
Does your fast key have a dead battery?
Have you tried manually inserting the key into the ignition? It's been a week. Hopefully you figure it out. |
Have you tried to check fuses to see if one is throwing everything off...
Originally Posted by Bom's Evo
(Post 11581190)
Originally Posted by Marty Baeza
(Post 11581311)
Hey buddy it's still a no go. I'm really thinking I need to take it to the dealership. I was hoping I can clear the code but it won't clear with my Cobb access port. I've changed my fast key battery already and also tried the regular key in the ignition. Wen I do that I won't even get a crank. But when I try it with the fast key the car will crank but still won't turn on. I've already installed a new battery also thinking it might have been that but nope...sucks man
I'd go with having some one check it out, no since in stressing yourself out too much and keep us posted!! |
The metal key still needs the 'mote to start.
Do you have another remote to use? If not - tow to dealership (and buy TWO remotes). |
| All times are GMT -7. The time now is 05:08 PM. |
