Car won't start
Old Feb 16, 2016 | 05:12 PM
Marty Baeza's Avatar
Car won't start
Can someone please help me! My ride will not start..everything is working fine in the ride lights,radio,power all fuses are good & Spark plugs.. I have a Cobb tuning and have checked codes. Has anyone else received this code
ECU
U0i67
Immobilizer communication error
Old Feb 25, 2016 | 06:05 AM
Bom's Evo's Avatar
Does your fast key have a dead battery?
Have you tried manually inserting the key into the ignition?
It's been a week. Hopefully you figure it out.
Old Feb 25, 2016 | 06:11 AM
machoymaru's Avatar
Have you tried to check fuses to see if one is throwing everything off...
Old Feb 25, 2016 | 09:03 AM
Hey buddy it's still a no go. I'm really thinking I need to take it to the dealership. I was hoping I can clear the code but it won't clear with my Cobb access port. I've changed my fast key battery already and also tried the regular key in the egnition. Wen I do that I won't even get a crank. But when I try it with the fast key the car will crank but still won't turn on. I've already installed a new battery also thinking it might have been that but nope...sucks man
Old Feb 25, 2016 | 11:26 AM
russ72's Avatar
Originally Posted by Marty Baeza
Hey buddy it's still a no go. I'm really thinking I need to take it to the dealership. I was hoping I can clear the code but it won't clear with my Cobb access port. I've changed my fast key battery already and also tried the regular key in the ignition. Wen I do that I won't even get a crank. But when I try it with the fast key the car will crank but still won't turn on. I've already installed a new battery also thinking it might have been that but nope...sucks man
I wish I was more mechanically inclined to help ya, but unfortunately I'm not. Maybe a bad starter or bad ignition contact or something. Just seems weird it won't crank with an actual key, but attempts to start with FAST KEY
I'd go with having some one check it out, no since in stressing yourself out too much and keep us posted!!
Old Mar 2, 2016 | 11:27 AM
Veronica's Avatar
The metal key still needs the 'mote to start.
Do you have another remote to use?
If not - tow to dealership (and buy TWO remotes).
Wmu240
Dec 18, 2015 10:18 AM
Wmu240
Sep 4, 2015 07:02 PM
HugePwnr
Apr 27, 2014 07:52 AM
MSP608
Aug 12, 2010 08:07 AM
geevolution
Dec 31, 2009 05:31 PM
