Evo Vendor 'Group Buy / Specials' Classifieds This forum is for any specials or group buys that vendors may have. If you're looking for the best price, this is the place to check. Please keep in mind that these items are not guaranteed to be in-stock.
Revolver valve spring/retainer buy is on...
Old Mar 27, 2005 | 12:13 PM
  #91
mitsuorder's Avatar
Hey badhabit, have fun with those keepers??? Those little guys suck
Old Mar 27, 2005 | 03:41 PM
  #92
Zeus's Avatar
Originally Posted by badhabit90
gots the springs and retainers in. WHAT A PAIN IN THE ARSS!!! i even had the right tools. definately not for the unskilled. BIG difference in springs noticed when installing the Revolver set versus the stock BEEHIVE spring and retainer. also installed ARP head studs and WORKS camshafts with the P2 flash. have to button it up and let her break in the cams. i think that will be later on this evening. it is 230am and im tired. will let everyone know how it went....and how she feels now.
Yes, this install is NOT for the unskilled/unexperienced... Now I "feel" much better about spinning her up though...
PS and thanks for the kudos guys. I've got a real busy week starting Monday... including my own clutch install.
...and a little buyer feed back from all you guys would be nice also
Old Mar 28, 2005 | 02:47 AM
  #93
badhabit90's Avatar
Talking
why yes i did there, little fellurrrr.....and you?? thank goodness for the neodimium magnets. i also stuffed the oil return holes with paper towels before i did anything. those little basturrrrds are a pain. luckily i had some white lithium laying around in a tube that helped keep em where they needed to be.
UPDATE ON INSTALL:
welp, buttoned it up and took her out for a little spin tonight after the cam break in. hit boost cut real quick now. im watching the boost gauge and it happens at about 21-22psi?????? it was suggested from WORKS that i put back in the stock intake box. i have the KN Typhoon intake and havent had one problem with it before. problem with the stock box is i broke one of the tabs where the MAF sensor bolts up to on the box. the MAF is okay, but the box has a small hole in it at a mounting point for the MAF. im also going to take out my MBC and install their boost hose assembly to see if that makes a difference. once i get more miles on the car, im sure the ECU will give smoother results.
CAMS: THANK YOU AND WELCOME BACK EVOMOTO FOR TAKING THE TIME TO POST UP A TUTORIAL THAT IS EASY TO UNDERSTAND. cams in the car definately helped. the idle is a little low, but that could be due to the intake flowing a little more air. you can hear the cams a little bit when they warm up, alot when its cold. pulls quite a bit now towards the top end all the way till 7800rpm. the power did fall off before at about 6500rpm for this car. torque was that same way. we shall see how it breaks in further.
HEADSTUDS: pretty straight forward. I USED THE SEARCH FEATURE to find a tutorial for the head studs. some of them say to torque to 60ft.lbs some others say 65, another one said use ARPs suggestions which is 70ft.lbs. with the moly lube or 85ft.lbs with 30w oil. but if you read further on the sheet that comes with the ARP studs it says "due to the expansion rate of aluminum, it is recommended that the torque should be 65ft.lbs with ARP moly assembly lubricant..." so i just made a happy medium and torqued them to an easy 70ft.lbs. i also used some loctite on the threads. JUST A SMALL DROP. and not the kind you have to heat up to remove. ive read a couple of threads where the head studs came loose. not good. i did do the hand tight thing and torqued them immediately. seems to have worked well thus far. i will check them in about 500 miles and retorque.
SPRINGS: THANK YOU REVOLVER CAMS AND ZEUS FOR THE EDUMACATION ON DUH SPRINGKS and the group buy in. these little fellers definitaly play a bigger roll on performance than people think. it took me about 3 hours for just the spring install from start to finish. luckily i had a OHV spring compressor already from a prior head reassembly. good to have the right tools the first time, even if you only have used them twice.....heehheehee!!! took my time and double checked everything. ALWAYS HAVE THAT LITTLE MAGNET RETRIEVAL TOOL HANDY!!! Zeus knows what i mean.....
OVERALL IMPRESSION: im happy with my purchases and will work out the boost cut issues and will be happy. im happy with the power and control of the car and i think im done with the modding for now.
the only other two mods i would like to do is the suspension and wheels. i havent decided if i want to go with the Hotchkis springs or do a TEIN Flex set up. i have the Flex/EDFC set up on my wifes IS300 and love it. i like the Hotchkis for the stance-not too low-and gives a great ride. it also leaves the car level, unlike the TEIN S tech which is a little lower in the front giving it the raked look and not level. for wheels, several choices-KENESIS wheels, HRE, or ??? havent really decided. alot of great choices, but have to set myself apart from the crowd. an awsome car deserves an awesome set of wheels. i have decided that they will be shiney black, but then again the Kenesis wheels look good dark grey. that will be next tax season though, i think. i have other things that need attending to first.
thank you everyone for reading and lets keep this EVO family strong......drive safe, shiney side up....
Old Mar 28, 2005 | 04:03 AM
  #94
EVO8LTW's Avatar
From reading all of the threads on this, I took away that around 80 with ARP moly lube on the nut and stud threads was the correct approach. Plus you need to cycle torque them -- still trying to figure out what that means. I think that means to tighten them and loosen them a handful of times before setting final torque, but I'm not sure.
EDIT: Just found this from a google search: "head studs, they must be torque cycled a total of 3 times. To properly torque cycle your fasteners, torque them to final recommended torque, then back them off one at a time and re-torque two more times. This allows the fastener to obtain its maximum stretch and clamping force for a better head gasket seal." In addition, it seems that it's also recommended to retorque them after a heat cycle or two.
Old Apr 20, 2005 | 11:46 AM
  #95
4ce fed's Avatar
Originally Posted by timzcat
If you hit it with air before disassembling the cams then you know when you have the crank dead up so the rod won't rotate it under pressure.
Can you expand on this, please? I obviously don't want the crank to turn any. If you pressurize a cylinder with air before you take the cams off, I can see that it will push the piston straight down as far as possible. What about the other 2 pistons that are totally at the top of their stroke? What will happen when you pressurize those cylinders? Even though the piston is pushing straight down on the rod, which puts pressure on the crank, you're saying that you don't have to worry about any pressure in the cylinder causing the crank to rotate? It seems like the slightest movement of anything will start the piston in that cylinder on the way down, throwing the crank off 180 degrees.
I guess my main concern is, how do you make it certain that the crank won't move while pressurizing a cylinder in order to hold the valves up?
Old Apr 20, 2005 | 11:58 AM
  #96
timzcat's Avatar
After doing it, your not going to stop the crank from moving. You need to take the belt off.
The idea is to have the piston at top dead center on the cylinder you are working on. When it is dead on the crank will not spin from the air pressure. This position takes a couple tries each time you move the crank. Get it for 1 and do the springs in 1&4 then move the crank to TDC for 2&3 and do the valves for 2&3. What tool do plan on using to compress the valve springs?
Old Apr 20, 2005 | 12:08 PM
  #97
4ce fed's Avatar
So it sounds like a timing belt job will need to be done using this method? I had planned on doing this the same time I did my cams, which leaves the t-belt strapped to the cam gears (using evomoto method). I guess this isn't happening the way I thought it would. I plan to use this: http://www.sjdiscounttools.com/sp91400.html. Revolver recommends it, and it's what Zeus used.
What else am I missing? Honestly, I've never done this before. I can handle the cams, no problem. I don't want to spend the day re-doing my t-belt if I don't have to. By the way someone said you don't want to "pull a Zeus", so I assume it can be done without having to redo the t-belt. Or did I read that section wrong?
Old Apr 20, 2005 | 12:21 PM
  #98
timzcat's Avatar
I said that before I did mine. To be honest I looked at the situation and said it's not going to happen unless I pull the belt off.
That is the tool I used and I will tell you now there is nowhere to mount it properly unless you remove 4 of the dowel pins where the cam caps go. You can just get 4 new ones because you'll probably destroy them getting them out. Done properly it will take you a good part of a day to do it. Where are you located?
There are also a bunch of gaskets and seals to consider replacing like you are supposed to. The other thng is, depending on your mileage you may want to pop for a new belt and tensioner. Your there, why reuse the old parts?
Parts for everything is about $200 from MP.net. I can give you all the part numbers and quantities of everything if you need it.
Old Apr 20, 2005 | 12:49 PM
  #99
4ce fed's Avatar
After reading about the crank turning, I figured the belt would have to come off. I've never done that, either. Looking at the service manual, it seems like a big job. Hard to understand why all that stuff needs to come off in order to time the car, until you get in and do it. Can you just remove the lower timing belt cover after the accessory belt is off and mark where the belt is on the crank pulley? I wouldn't be messing with the balance shaft belt, so that shouldn't have to be redone. I'm in central Alabama.
I've got 25K on the clock, so I hadn't considered a new belt or anything. But that was before I knew the t-belt had to come off.
Old Apr 20, 2005 | 01:06 PM
  #100
timzcat's Avatar
It is a decent amount of work but it's not horrible. If you take the timing covers off you can remove the tensioner and belt. You need to remove some stuff to get at the cover though. Water pump pulley is tricky. You have to lower the engine to get to the bolts through an access hole in the frame. There are 2 balance shafts, the one in the back is driven by a belt, the one up front is driven by the oil pump. The only real reason to remove the DP and undertray is to insert a screw driver in an access hole to make sure the balance shaft is in the right position. If you don't move the front blance shaft you can get away without taking all of DP and stuff off.
A belt and tensioner is deffinitely worth considering since you are all ready there and the Mitsu tensioner is not know for it's reliability long term.
Old Apr 20, 2005 | 01:32 PM
  #101
Zeus's Avatar
Short notes... I'm in a hurry:
You can replace the valve springs while using the Evomoto cam swap guide, and with the cylinders pressurized to 110psi... the catch is that you can not rotate the crank while doing so. IF YOU DROP A VALVE WITH A PISTON AT BDC, YOU WILL HAVE TO PULL THE HEAD. So if you lose your air pressure, your job just became a two day affair for the novice/quasi-mechanic. I do not recommend this method to you, but have done it myself this way.
BUY the AMS tensioner tool for $40! it is worth it's weight in gold... got to love a chromoly tensioner tool. I've used it many times now, and it is no where near worn. Use a light touch with 1/4 turns waiting a several seconds between them to allow the tensioner to properly compress.
No more time, got to go...
Old Apr 21, 2005 | 05:19 AM
  #102
4ce fed's Avatar
How would I keep the crank from turning? The only way I can think of is pressurizing every cylinder at the same time. I already have a tensioner tool from RRE.
timzcat, sent you a PM.
Old Apr 21, 2005 | 02:59 PM
  #103
timzcat's Avatar
Parts list for spring and retainer replacement
2 MD372536 Cam Seal
4 MD132806 Cam cap dowel pin Iif using the sjdiscounttools spring comp.)
1 MD329503 Cam sensor housing cover gasket
Optional Parts
1 MR984375 Belt Tensioner
1 MD369999 Tensioner Pulley
1 MD326059 Timing Belt
1 MD340535 valve cover gasket
4 MD186785 valve cover spark plug grommets
1 MD016483 Valve keepers
Old Apr 25, 2005 | 07:04 PM
  #104
justchil's Avatar
Can I get a set of these still? I'm going to have cams/studs install soon.. I might as well spend a couple hundred more and do it right.
DatEngnr_Bro
Mar 13, 2017 06:06 PM
Shaun@AWDMotorsports
EvoX 'For Sale' Engine Internals and Drivetrain
110
Dec 6, 2016 04:52 PM
Gtizks
Dec 5, 2015 03:03 PM
Gruppe-S
Evo 'For Sale' Suspension / Brakes / Handling
280
Jul 13, 2010 04:49 PM
Speed Element
Feb 24, 2009 05:11 PM
