Nisei intercooler installed
Originally Posted by nickracer9
yeah it fits the stock pipes and comes with t-bolts and silicone couplers. it is very well designed and not just a spearco core with endtanks welded on.
This is weird to me. Maybe cause I was in a much higher ambient temp with high humidity, but on my last trip to the dragstrip I logged my intake temps on the runs and at a 26 psi spike, my intake temps went from 137 degrees leaving the line to 105 at the top of the track. Ambient temp was around 80 degrees. This is with the stock intercooler and piping. Now I understand that my temps dropped cause the car went from sitting still to moving, what I dont understand is how your car gained temp doing the same thing. Is this from heat soaking the stock intercooler while waiting in line to make a pass? If so, did you log your runs while the car was cold and shut off, just started it up and drove it down the street? If anyone can explain this it would help, thanks.
I have been testing a Neisei FMIC. I have noticed tipically a 2- 5 degree max difference in intake temps compared to ambient at the end of pulls. Got to test it on the track under 100 degree ambient and my intake air temps were 101 degrees.
With the AVO i used to have, I would see a 20 degree jump in temps at the end of a pull or run session. The thing is really over built and it is a bit heavier than the avo also.
Originally Posted by Richard Sierra
The stock injectors are over 95% duty cycle worst case.
Did you notice a change in coolant temp at all with a bigger FMIC in front of your radiator?
Ambient temp was approx 60 degrees F for both the stock and Nisei IC.
Actual intake air temp started about 65 and went to approx. 100 for the stock IC.
The Nisei delta was actual intake temp, in other words the intake temp started about 60 and went to 67. Ambient was approx 60.
Originally Posted by value
I like their cooler but not having a I/C piping kit to go with it is like doing a halfway complete job. I read their working on one soon I hope. Just my 2 cents.
The difference is due to my runs starting around ambient versus yours that started way above ambient temperature.
