DynoFlash [Visit Site]
"V4" Boost Controlling Flash option on IX Evos
Old Jan 8, 2006 | 01:27 PM
DynoFlash's Avatar
Guys - tuning here in sunny FL - spent two days finalizing the details of the new "V4" boost controlling flash - here in a bone stock 2006 Evo IX
This new product includes a reflash (custom or through the mail) and a propietary Boost Hose which has a revsed boost pill configuration
I spent a lot of time with David Buschur perfecting this arrangement on the BR350 car and now I have it working OEM quality on the 2006 IX
The boost peaks at just over 20 psi and tapers to 18.5 or so
The boost holds the same in all gears
As you can see from the attached log the quality and results are near OEM quality - in fact it works much better and smoother than the OEM controls
It took a lot of work - but the results are superior to a MBC or EBC at this point as the oem ecu continues to have the ability to lower the boost level while you are warming up and when and if you may pick up a bad tank of gas to protect your motor.
For the time being this is offered ONLY to STOCK EVO IX's only - I will have it woking on modified cars in a short period of time
Old Jan 8, 2006 | 01:32 PM
DynoFlash's Avatar
The previous pull was in 4th gear
Here is same car witha 3rd gear pull - the boost hits same point - falls down a slight bit more
Main thrust is that its smooth - linear and works amazing in all gears
Attached Thumbnails "V4" Boost Controlling Flash option on IX Evos-rnm3rd.jpg
Old Jan 8, 2006 | 01:35 PM
DynoFlash's Avatar
The G meter was not flat to the floor qwhen I was taking out the equiopment adn thus the number was prob a bit high - none the less it was a very fast car
The Evo IX stock with this flash and boost hose is almost as fast and many 2003 Stage 3 cars - the IX's really are amazing cars
Old Jan 8, 2006 | 02:08 PM
DynoFlash's Avatar
At this point - as a promotional marketing program - I will include the verised boost hoses and "V4" boost controlling settings for FREE with all Evo IX flashes - mail in and custom - through Feb 1 (Mail in is $299 for IX which includes refturn fed ex and the boost hose through Feb 1)
After Feb 1 there will be an additional charge for this feature
(Installation of boost hose is $50.00 extra charge)
Old Jan 8, 2006 | 08:52 PM
joshd's Avatar
Al - thanks for taking the time to post ... since I know you have been busy.
I guess bring an extra one of these to D.C. with you please
Question though ... do you think it would be safe with a stock IX to hit a slightly higher boost peak, like around 22psi ... and then let the natural taper happen from there? Or would that be pushing it too much on 93 octane?
Old Jan 8, 2006 | 09:08 PM
DynoFlash's Avatar
I would say that on a street car 21 is the limit on what I would suggest - I am perhapse overly prudent ?
This level is a good one for a stock car and the car was fast as all heck for a 100% stock car
Old Jan 8, 2006 | 09:19 PM
hukster00's Avatar
How much is the fully custom tune for Evo 9 ?
Old Jan 8, 2006 | 09:24 PM
DynoFlash's Avatar
$475 fully custom tuned on the dyno heer in Ct at pruven or road tune on my various road trips
Its $300 base flash shipped fed ex
Old Jan 9, 2006 | 12:33 AM
David Buschur's Avatar
Very nice work Al. Glad after all the work you have it working so well. That's about as flat a boost line as it can get.
David Buschur
www.buschurracing.com
Old Jan 9, 2006 | 05:52 AM
joshd's Avatar
Looks great, and not having the MBC is obviously more warranty friendly ... for whatever that is worth ...
You just lose the adjustability of the MBC ... I wonder if there's any way to supply the end user with different hoses with different restrictions that could be swapped out to achieve different boost levels as desired? Might not be doable, but just a thought for fun
Also, how much headroom has this bought you in terms of the wastegate duty cycle? How high can you run the boost and still control it through the factory ECU + your boost tubes? For example if one were to run a bigger turbo or alky/race gas. Just thinking out loud
Old Jan 9, 2006 | 10:59 PM
DynoFlash's Avatar
No the pill must macth the ecu tuning and this process takes hours
Old Jan 9, 2006 | 11:06 PM
Abicus's Avatar
This is great news Al. As much as I love my dynoflash tune, I was considering switching to the AEM after reading David's results using to standalone to control boost. However, would your V4 flash be able to maintain 27psi or so to redline given a high boost acuator. I'm interested in this by april or so when you come back to the northwest. Thanks.
Old Jan 11, 2006 | 11:23 AM
White white IX's Avatar
Hey Al. Is this boost hose sold with both ECUtek and dynoflash tunes
Old Jan 11, 2006 | 12:37 PM
Warrtalon's Avatar
I believe this is just for the Dynoflash, but there's no need to get EcuTek flashes anymore. The only reason there was a reason before was because no one had figured out the TechTom flash yet. Al has it figured out, so you can just get the Dynoflash for much less now...
Old Jan 11, 2006 | 12:42 PM
RobDogg's Avatar
Is the boost hose easy for any one to install, or have installed? if i get a mail-in that is, no ecutek license fee sounds great
