stock IC - bottleneck for a green turbo?
They didn't have time to do any tuning for today. I have schedule an appointment for this coming saturday. Hey slowcar what do you think about the Perrin meth injection kit with the failsafe? From looking at the specs of it, that kit seem very similar to the Aquamist kits. They use the same pump but different interface set up for the failsafe. Just want your info on the two kit if you can please.
Thank you.
Thank you.
Thank you.
Thank you.
The other aquamist system, the recently introduced HFS-5. Due to the bigger pump used, will be able to support more aggressive tuning or bigger turbo systems. It also has the capability of being able to be driven by a aftermarket ECU - you can create your own injection map.
Either way, you are looking at the safest and the best put together system in the WAI industry.
Abner,
I think that in page two you had a few responses from people that already tested bigger IC and went back to stock. Keep the stocker IC and just inject plenty of methanol.
Carlos
Carlos
it looks like the direction i'm heading for now. I'm also thinking of going intercoolerless......
Even with a ****y small intercooler the benefits of reliability and performance are worth. Running a turbo car without any kind of intercooler is now days absolutely unconcibeable/prohibited.
You would not cool the air fast enough with your methanol to make it decently and safely cool. Remember the principle of the Air condition units, you need the heat expansion, an intercooler is absolutely critical specially with the amount of hot air and boost you will be putting at 26psi.
I work with targeting pods at work, even the targeting pods which are installed in jets that travel anywhere from 600-1800mph requires some heat exchangers (intercoolers) to cool down various components.
Abner, No. That is out of the question.
Carlos
Since you actually seem serious about deleting the FMIC, I decided to dig out that old dyno testing thread from Dave Buschur where he deleted the FMIC and lost a bunch of power. He wasn't shooting as much meth as you are, but the loss was quite dramatic. I just posted a link in the other thread.
