external wastegate
Old Aug 23, 2007 | 05:13 PM
sparky's Avatar
I got these definitions online, from, Eric Fahlgren's, "TURBO GLOSSARY".
Boost Creep: Occurs when the wastegate/turbocharger combination is improperly sized and cannot dump enough exhaust gases. The symptom is rising boost as RPM's rise...To reduce this effect, either install a larger capacity wastegate or a turbine housing with a higher A/R ratio.
Boost Taper: A phomenon produced by flawed boost controllers, which causes boost to drop(or taper off) when it should remain steady.
Old Aug 23, 2007 | 05:26 PM
sikrsix's Avatar
Originally Posted by MitsuJDM
I think you should go into business making/selling them because I, along with many other members really want one
Funny how when I threw my custom 02 dump up for sale it took months to sell and I practically gave it away! But how I miss being louder than a harley!!
Old Aug 23, 2007 | 07:42 PM
MitsuJDM's Avatar
Originally Posted by sabastian458
I have an AMS lower piping Hell, if you can make the housing with just a few inches of dump tube and seen some spare tubing detached from the housing, I can have the rest plumbed arround to where it needed to be
Yeah, you can just use that flexable tubing. I used that to run the wastegate out my bumper on my Mirage. Works great
Old Aug 23, 2007 | 09:45 PM
volks-traitor's Avatar
has anyone tried merging the dump tube into the down pipe further downstream? back to the cat/testpipe. quieter and less turbulent. i suppose packaging could be a problem.
Old Aug 23, 2007 | 10:01 PM
sparky's Avatar
Yeah, if I recall, Soon2BEVO says that merging is a b*tch plumbingwise.
Old Aug 23, 2007 | 10:07 PM
evo420's Avatar
found this.
J Speed High Power Front Pipe
(Exhaust)
http://www.bulletproofautomotive.com...il.php?ID=1873
Old Aug 23, 2007 | 10:15 PM
evo420's Avatar
looks like an improvement over stock. but what are the draw backs
Old Aug 24, 2007 | 02:13 PM
MitsuJDM's Avatar
That looks sweet. I wonder if you'll bolt to other aftermarket exhaust/testpipes/cats.
Old Aug 24, 2007 | 03:23 PM
riceball777's Avatar
i just did it on my buschur manifold
i have the old buschur br500bb which uses a cheap internal gate.
so i just welded a tial 44mm on then and am running a open dump tube
works great for me. no boost creep no boot taper. but i am runing a 30r
05VIII
Dec 2, 2010 06:43 PM
11secMR
May 21, 2008 11:56 PM
Forrest Gump 9
13
Nov 1, 2007 08:17 AM
Jrod@Buschur
May 25, 2007 08:52 AM
AfireINSIDE
Mar 23, 2007 04:50 PM
