Extreme Turbo System Customer's Track Times and Dyno #s
Dman u forgot me already, lol ^^ 61mm
Let me give back a better timeline.
In April did 502WTQ/419WTQ on Dynojet.
Different mods from first post are: Dual meth nozzles, 3inch UICP conversion.
Did 475WHP/419WTQ on Mustang dyno
Retarded Cam gears to -4/-4, Swapped Exhaust to 3 1/4" non resonated unit.
Essentially picked up a hell of a lot of TQ and prolly 20WHP or so over the dynojet numbers.
Also this was done win 90*, 100% humidity weather.
Next set of mods, upgraded Cams, low lift 10.2mm HKS cams gotta go.
I am wary of pushing more than 32psi on stock rods.
__________________
__________________
__________________
__________________
Forgive him.
__________________
__________________
haha...sorry man, i forget people pretty quickly if i dont talk to them all the time. I remember you now. Very nice and i am very impressed with your results. When are you hitting the track?
Thanks for the backup bro....yeah i have been distracted a little. The evo is gonna be done soon and since i got the Supra back from the body shop i have been playing with it a bit. I am gonna build that one now, since i sold the 911 for a killing
I wonder if i have the highest WHP and TQ. GT35R ? eveyrthing is done in house by my shop/me
mods.
Built 2.0l block.
1mm oversize valves head
Hks 272/272 cams
stock cams gears
straight 3" pipe exhaust.
Magnus Intake Manifold "Bushwack doesn't think it works
Autronic ECU
619whp 550ft-lb TQ @ 11.8 AFR @ 28.2psi C-16. Also my dyno 15% lower than dynojet. Been confirmed over and over.
mods.
Built 2.0l block.
Hks 272/272 cams
stock cams gears
"Autronic ECU
So the other night I went to PIR since my car is all back together.
I get up to the line and all I can think about is how my **** blew up here 2 months ago and sucked my life away. I am so deeeeply thankful that Lucas let me borrow the dually the whole time and made sure I had something to drive when I needed it.
enough of that.
So I am sitting there, tires aired down to 25psi (it was 20 when it blew up), boost set at 27 from street duty (I forgot to up it for track drop...remember this because it comes into play later), rev limiter set to 5250, and E30 in the tank.
I feel pretty invincible since I think I'll ride the clutch, make my new hybrid 5 speed work for the mph (e.t. wasnt my concern) and see what the really high VIII 4th gear is good for.
I launch slow, 1.97 60' (I normally run mid 1.6), shift kind of delibrate and dont use the NLTS at all, and let it eat in 4th for what seems like forever. I get to the time shack expecting a 13, and I look and am surprised to see a 12.23......AT 119.7!!!!!
This is a full mph faster than my best previous time of 11.54@118.7 on the 6 speed with stock cams. I get to the pits and talk with some of my friends that showed up and TJ, Kevin, and Myles and then look at the log. I ran that with a peak boost of 23psi on the Green. Most of the run was actually 21psi. The speed that was logged is actually really alot more accurate than I thought it was since when I ran the 11.54 it logged 120, and the night the timing lights died it was in the 123-124 range.
I am stoked to run faster with more boost. The GSC S2 cams and the ETS 4" FMIC make the difference I think. That night I missed a shift on my next pass, and then there was a wreck and it got way crowded so I didnt get any faster times before I left. The car definitely has more in it, and I am gonna start playing with more of a mix...maybe VP109 and 50% Eth.
log-
enough of that.
log-
Time slip for those that are interested.
Thanks Monti
Tom-Not this weekend but next Friday we will be there in force and with the newest ETS monster...Jeff's 1G will be up and running making spring pressure passes.
Everyone needs to come out and see this if you have the DSM flava and the 1G love. Not all 1G's are Sand Talons...lol
I'll be there for that!
