Difference between evo 8 and evo 9 gearing
Old Jul 26, 2008 | 01:35 PM
john.schuber's Avatar
Does anyone have the gearing information for the 8 and 9. No so much the ratios but stock mph max in each gear. Is the 8 that much higher in fourth since a lot of drag racers switch them out. Also does the buschur and ams drag car have a fifth gear or are they both geared to max out 170+ in fourth.
Old Jul 26, 2008 | 04:34 PM
Davethewave's Avatar
bro, im not sure, but i think AMS and Buschur both use a "DOGBOX" or dogbox style tranny, no syncros, horrible for street driving. im pretty sure its clutchless.
i read about them in some import mag it said something about the gears like
"think pitbull teath rather than chiuaua teeth"
Old Jul 26, 2008 | 05:28 PM
FloopyDisk's Avatar
Stock they're both limited to 155.
Old Jul 26, 2008 | 05:47 PM
huevosrancheros's Avatar
bump for info as well. As far as i heard the evo 8 tranny is better than 9, not sure if that is true or not.
Old Jul 26, 2008 | 05:58 PM
yellowebo's Avatar
To date, 5-8-08 has ran a best pass so far is of 8.88 and a best MPH of 172.74
Old Jul 26, 2008 | 09:32 PM
I'm pretty positive the 4th gear on the 8 is longer. I just don't know how big a difference they are mph wise. Bump for gear ratios and mph differences
Old Jul 26, 2008 | 09:34 PM
diezilnj's Avatar
does the 8 tranny bolt right up to a 9?
Old Jul 27, 2008 | 09:37 AM
MrJdmJimi's Avatar
yep will bolt right up .. evo 8 has longer 1st 4th and 5th i believe .. evo 9 has shorter gears better for auto x
Old Jul 27, 2008 | 09:49 AM
silver9mr's Avatar
well from experience the 8 4th gear is much longer than the 9. i will redline at about 8200k at 110 mph in my 9 and my friends 8 will do about 115 at only 7000k
Old Jul 27, 2008 | 11:29 AM
Ludikraut's Avatar
Stock Final Drive Ratio: 4.529
Gearing VIII/5 - IX GSR- IX MR
1st Gear 2.928 - 2.785 - 2.909
2nd Gear 1.950 - 1.950 - 1.944
3rd Gear 1.407 - 1.444 - 1.434
4th Gear 1.031 - 1.096 - 1.100
5th Gear 0.720 - 0.761 - 0.868
6th Gear -.--- - -.--- - 0.693
Speed with stock final drive, 7500 RPM:
------------ 4th --- 5th --- 6th gear
VIII 5speed: 121.7 - 174.3 - n/a
IX GSR 5spd: 114.5 - 164.9 - n/a
IX MR 6spd.: 114.1 - 144.6 - 181.1
Speed with stock final drive, 8000 RPM:
VIII 5speed: 129.8 - 185.9 - n/a
IX GSR 5spd: 122.1 - 175.9 - n/a
IX MR 6spd.: 121.7 - 154.2 - 193.2
Speed with HKS 4.11 final drive, 8000 RPM:
VIII 5speed: 143.1 - 204.9 - n/a
IX GSR 5spd: 134.6 - 193.8 - n/a
IX MR 6spd.: 134.1 - 169.9 - 212.8
Speed with TRE 3.84 final drive, 8000 RPM:
VIII 5speed: 153.1 - 219.3 - n/a
IX GSR 5spd: 144.0 - 207.5 - n/a
IX MR 6spd.: 143.5 - 181.9 - 227.8
All speeds are in MPH.
l8r)
Attached Thumbnails Difference between evo 8 and evo 9 gearing-gear-ratios.jpg
Old Jul 27, 2008 | 11:32 AM
Ludikraut's Avatar
IIRC, neither Buschur, nor AMS has gone to a dogbox yet. Both are using non-stock final drive ratios, though.
l8r)
Old Jul 27, 2008 | 11:37 AM
4kinboost's Avatar
l8r)
Great Info!!
Old Jul 27, 2008 | 11:39 AM
4kinboost's Avatar
l8r)
Which final drive is Buschur using to get that 155mph trap?
Old Jul 27, 2008 | 11:43 AM
Ludikraut's Avatar
Not sure. AFAIK, only the 3.84 and 4.11 final drives are available for our Evos, though. It's also not uncommon to see people mix and match between the various tranny gears (except for the MR 4th and 5th gears) in an attempt to fine tune the gearing.
Personally I'd really like to see something close to a .096 4th gear to be made available.
l8r)
Old Jul 27, 2008 | 11:45 AM
Evo2wIsh4's Avatar
l8r)
Thanks for this info!! I needed it
