Difference between evo 8 and evo 9 gearing
Does anyone have the gearing information for the 8 and 9. No so much the ratios but stock mph max in each gear. Is the 8 that much higher in fourth since a lot of drag racers switch them out. Also does the buschur and ams drag car have a fifth gear or are they both geared to max out 170+ in fourth.
bro, im not sure, but i think AMS and Buschur both use a "DOGBOX" or dogbox style tranny, no syncros, horrible for street driving. im pretty sure its clutchless.
i read about them in some import mag it said something about the gears like
"think pitbull teath rather than chiuaua teeth"
Stock Final Drive Ratio: 4.529
Gearing VIII/5 - IX GSR- IX MR
1st Gear 2.928 - 2.785 - 2.909
2nd Gear 1.950 - 1.950 - 1.944
3rd Gear 1.407 - 1.444 - 1.434
4th Gear 1.031 - 1.096 - 1.100
5th Gear 0.720 - 0.761 - 0.868
6th Gear -.--- - -.--- - 0.693
Speed with stock final drive, 7500 RPM:
------------ 4th --- 5th --- 6th gear
VIII 5speed: 121.7 - 174.3 - n/a
IX GSR 5spd: 114.5 - 164.9 - n/a
IX MR 6spd.: 114.1 - 144.6 - 181.1
Speed with stock final drive, 8000 RPM:
VIII 5speed: 129.8 - 185.9 - n/a
IX GSR 5spd: 122.1 - 175.9 - n/a
IX MR 6spd.: 121.7 - 154.2 - 193.2
Speed with HKS 4.11 final drive, 8000 RPM:
VIII 5speed: 143.1 - 204.9 - n/a
IX GSR 5spd: 134.6 - 193.8 - n/a
IX MR 6spd.: 134.1 - 169.9 - 212.8
Speed with TRE 3.84 final drive, 8000 RPM:
VIII 5speed: 153.1 - 219.3 - n/a
IX GSR 5spd: 144.0 - 207.5 - n/a
IX MR 6spd.: 143.5 - 181.9 - 227.8
All speeds are in MPH.
l8r)
l8r)
l8r)
l8r)
l8r)
Great Info!!
Not sure. AFAIK, only the 3.84 and 4.11 final drives are available for our Evos, though. It's also not uncommon to see people mix and match between the various tranny gears (except for the MR 4th and 5th gears) in an attempt to fine tune the gearing.
Personally I'd really like to see something close to a .096 4th gear to be made available.
l8r)
l8r)
l8r)
l8r)
Thanks for this info!! I needed it
