Speed sensor for aftermarket navi
Old May 23, 2008 | 11:22 PM
singo's Avatar
The shop guy who installed my Eclipse AVN6620 told me that he coudnt find the speed sensor. Although my navi works fine it doesnt work smooth(it bumps alot)
Anyone can help me with this problem? Thank you
Old Jun 19, 2008 | 07:22 PM
jason_ttu's Avatar
I seconed the request to know where the speed sensor wire is.
Old Aug 2, 2008 | 07:31 PM
salukidude's Avatar
I third.
Old Aug 4, 2008 | 12:49 PM
jamesfr's Avatar
+1
Old Aug 11, 2008 | 03:44 PM
salukidude's Avatar
I heard today that the vss wire is brown/white at the ECU; drivers side of the cabin intake filter. I've pretty much ditched my plans and don't have a need for this now. Hope this helps someone.
Old Aug 11, 2008 | 08:27 PM
spydy98's Avatar
it may also be a can bus wire. which would mean it will b some time befor anyone will have an adapter to read it
Old Aug 11, 2008 | 08:33 PM
salukidude's Avatar
I don't think so. The dealer and I called a vendor. They asked if it was the Rockford 9-speaker system, we said yes, and they definitevly said brown/white wire at the ECU next to the cabin air filter.
Old Aug 14, 2008 | 08:24 PM
untuned's Avatar
i have a gsr non sss package. there is a connector for the stock navi unit i was looking at the manual and it said that C-13 is a VSS singal. Would this wire work?
Old Aug 14, 2008 | 09:41 PM
xPRimNT's Avatar
I think you're on the right track. C-13 is probably the harness that the VSS wire goes into. If you can find out what color the wire is, you're golden.
If you don't have an answer by tomorrow, I'll dig in a bit.
Old Aug 15, 2008 | 04:31 PM
untuned's Avatar
it's pin 13.. BUT the manual doesn't give you a connect view of it. so I think I'm gonna stuck my meter in and check for an a/c singal.. it can only be one of the wires in that 17 pin connector LOL
just look at the manual and it said C-13 pin 13 R-G I'm guessing it's red with green tracer, I'll update with my install tomorrow..
Old Aug 17, 2008 | 12:10 PM
jason_ttu's Avatar
just to clearify things what manual are you looking in, and if it the service manual where. i have only been able to find the vss going into the ecu. would rather grab the vss from the navagation plug like your saying.
Old Aug 17, 2008 | 05:56 PM
untuned's Avatar
ok I'm look at the service manual. well i installed my deck this weekend, and the vss is on the C107 connector pin 31 i think it was a white with blue tracer (note that the connector itself is 20 pins they just lablel it funny) not the c103 connector. The c103 connector is only if you have the factory navi. here is the copy and paste from the service manual
this is the big connector that plugs into the deck in the back, the other connector is for the can-bus. i forgot to take a picture. here's a pic of the vss output on my f900bt
it's reading 66.72km couldn't get a good shot, hope this helps.
Old Aug 17, 2008 | 08:27 PM
xPRimNT's Avatar
Nice. Thanks for the details!
I'm sure it will help lots of people with installs. I didn't have a need for VSS on my non-Nav deck, so I didn't look into it too much.
Old Aug 17, 2008 | 08:42 PM
jason_ttu's Avatar
Cool thanks for the visual, the service manual is just to vast for me to find anything. i still couldent find that page but it dosent matter. i will try that conector when i install later this week.
Old Aug 20, 2008 | 09:13 PM
schwartz1's Avatar
you have any problems with your F900BT btw? can you PM me? I have some questions about it that you may be able to answer about it.
