Logging with the (Beta) Standalone Tactrix Cable Logger (No More Computer!)
Yeah, I assumed it was 2 byte in looking at the value it was spitting out, but my original equation for 2 byte was assuming x/65535 instead of x/1023... so it had me really confuzzled. All good now though!
FYI, my current logcfg is here for anyone that wants to use it:
http://thefrost.net/randomfiles/tuni...810.logcfg.txt
I know this is a terrible question, but is there any way to get the remote logger to work for the IX. I have the 2.0 cable and a SD card. I was going to try and set this up for logging in a week or so.... Also, if this will work, what WBO2 are you using fostyou?
The trigger would work the same, you just need to know the address of a memory location to trigger on. The 8's have an IC cooler sprayer button. The X has a cruise control button. I'm not sure what you could key off of for the 9. (Never driven one)
I'll try to build a cable when I get back from Deal's Gap this weekend.
Does anyone know if it is possible to get the standalone logging to have a more precise time scale like in the Evoscan logs, i.e., LogEntrySeconds? I wired up my ECU ADC to my wideband and everything works great but Virtual Dyno cannot plot the run worth **** because the only time scale in the logs is <time> which doesn't provide a smooth graph at all due to the lack of resolution. It looks like a set of bear teeth when plotted.
Thanks!
Thanks!
Yeah, it's probably due to logging too much stuff. The standalone does not log very fast. The drive could limit it too... I say could, because it's not writing that much data, so I don't know how fast it needs to be, but if the flash has to erase a sector, it could cause some good lag.
