Boost Tapering
Okay, I got the GM Boost solenoid in today. However, it didn't come with the connector/pigtail. I emailed gmpartsdirect and they said they no longer make it. Does this sound right?
Thanks,
Thanks,
I installed the GM solenoid and was able to eliminate the taper. The car holds 20-21 psi to 7500 rpm. This is with 280 cams.
With the MBC the best the car would do was about 17-18 at redline. Probably picked up about 20-30hp for about $40.00.
, That's almost stock. I was hoping it would hold atleast 25. Which one holds more than 20?
