AEM EMS Get tuning help for your AEM EMS system.
Tuner Lite to AEM??
Old Apr 30, 2005 | 01:06 PM
liberty2000rs's Avatar
Tuner Lite to AEM??
I just installed my AEM and speed density setup. Im wondering if anyone has used a turbo-xs wideband set-up with the AEM and if so, where they referenced the 5volts from.
Old Apr 30, 2005 | 04:47 PM
MalibuJack's Avatar
Do you have the tuner or tuner pro? If you have the Tuner Pro, there's a two pin connector on the side of the Unit that can be configured to provide an appropriate scaled output (bottom pin, the upper pin is a narrowband output)
On the regular tuner, I'm not aware of any outputs for the wideband, but you'll have to check the Docs to be sure.
Just remember, you'll have to go into the Tuner parameters and set the lambda values for rich and lean so it has the appropriate scaling, then do the same for the input on the AEM then compare the two to be sure they both are reading the same thing.
Although I didn't hook up a tuner pro to the AEM, I did hook the Tuner pro up to a PLXDevices 5v Wideband gauge, so I had to set the calibration up so it read correctly on the gauge.. Its basically the same thing.
Old Apr 30, 2005 | 04:49 PM
MalibuJack's Avatar
Oops.. Tuner lite.. Check the side of the unit for a 2 pin connector..
Old Apr 30, 2005 | 09:29 PM
cool, thanks again Jack, I figured I could count on you!!
