AEM EMS Get tuning help for your AEM EMS system.
Question and setup bout Accel and decel inputs.
Old May 3, 2005 | 02:05 PM
TheeVOoNE's Avatar
What inputs/value do you guys have for these variables:
Accel dTPS trigger: mine=1
Accel Limit: mine=36%
Accel Pump Sustain: mine=5%
Accel TP Sensitivity: mine=92%
Accel dLoad Trigger: mine=100
Decel Decay: mine=0%
Also I'm getting horrible gas mileage, about 120/tank(light driving). Was wondering if any other inputs might need to be changed. Fuel map seems legit, is there anything I'm missing?
If anyone can help, please advise.
Old May 3, 2005 | 03:02 PM
GTVEVO's Avatar
I think your trigger is a little low and your sustation looks low as well. I have my trigger set at 6 and my pump sustation is about 15% with a sensitivity of 95%. With a trigger of 1 you are adding fuel for every little touch of the throttle even though it isn't staying long. This might help you out a little but but your bad gas mileage is probably more to due with your fuel map.
I am running 850cc injectors and I have very good mileage Just as good if not better than stock, if I can keep my foot out of it that is. If you have these setting low due to low rpm driveability you need to take advantage of using the Throttle Inj Correct table. This table will help you alot with low rpm and low load driveability. Just be careful becuase you can end up leaning out your entire fuel map as well.
Hope it helps.
Old May 3, 2005 | 04:08 PM
TheeVOoNE's Avatar
PMed you about a Q.
Old Dec 20, 2009 | 08:03 AM
MagicManRed's Avatar
U guys notice that the higher the "accel limit" the more responsive the motor seems to feel when stationary?
Is putting that to 100 a bad thing?
Raceghost
Nov 14, 2016 11:55 PM
MREVO9NOOB
Sep 27, 2016 06:15 AM
foxbat
Mar 20, 2016 03:50 AM
Eisen7
Nov 10, 2015 01:51 PM
widge
Sep 2, 2012 02:39 PM
