AEM EMS Get tuning help for your AEM EMS system.
Both Computer and Tuning Literate
Old Nov 10, 2005 | 01:24 PM
QuickEvo's Avatar
At this point I really feel like a moron. I can not get the EMS to communicate with my laptop. COM ports between the two match, and my laptop tells me the COM port is active and the device is enabled. However, I can not get the two to communicate. If anyone has any constructive advice let me know.
Old Nov 10, 2005 | 01:39 PM
Ev0ikon's Avatar
Try disable the port, and uninstall it. Then reboot and reinstall the port. It would be windows' brainfart.
Old Nov 10, 2005 | 04:44 PM
FLAEVO's Avatar
Mine did the same thing on port 3 it connected but wouid comunicate Ihad to keep
going until i got to port 5. Keep trying all the ports I think there are 9 of them.
Old Nov 11, 2005 | 05:34 PM
strikethree's Avatar
You neglected to specify if you were using an USB to Serial adapter or a built-in serial port.
No matter which type of serial port that you are using, make sure your port settings are correct (8N1) and that the key is turned on past the Accesory setting but before it actually cranks the engine over. If it is still not working, try a lower serial port speed.
HTH,
strike
Old Nov 12, 2005 | 12:05 PM
QuickEvo's Avatar
It turns out the serial port on my laptop is bad. I used a loop tester to discover it. A simple USB to serial converter fixed the problem.
