AEM EMS tuning now i'm desperate
HI need help with my AEM EMS I hate to result to this but I’m desperate
here are my engine mods
DNP manifold with gt3071 turbo and tial wastegate
HKS 272 intake and exhuast cams
Custom spearco intercooler and piping with HKS SSBOV
Buschur racing 255 liter fuel pump and 780cc injectors
HKS HI-TI full exhuast system and intake
AEM EMS and 3.5 bar map and AIT (maf delete basically) also gm boost soleniod
of course I have gauges and clutch tein basics and a few other mods that really don’t matter to the ems tuning Is there anyone out there with AEM base map with same or close to mods . I use to have a AFC2 but sold it as soon as I got an AEM thinking I would no longer need it wish I had keeped it at least till a got the AEM tuned. I’m having trouble with my tuning on ems and would be grateful if someone was willing to help with a base map for my mods good enough to get to a dyno my stock ecu doesn’t work well with the mods and is hardly drivable to get to a good AEM tuner I’d say the closest one is near 6 hours away in KC and yes i have uploaded the base map for the evo8 with same results as the stock ECU near nect to no difference in drivability iv'e read through the guide and i think i'm more confused than before i read it or maybe i'm just an idiot?
thanks for reading
PS. willing to pay for your base map with same or close to mods yes I’m that desperate
Thanks for reading
thanks for reading
Thanks for reading
DONT BLOW UP YOUR RIDE!! Where exactly are you? I think a drive for 6 hours is better than blowing your car up. Better yet, have it towed there. Call AEM and see where their closest "certified" tuner is located by you. Good luck.
yes, you need to just trailer your car to the dyno.
if you've read the efi basics document several times and are still clueless, then you're better of f just relaxing and letting the pros do it.
thanks for reading
Thanks for reading
thanks for reading
Thanks for reading
trailer is a good idea at the monment anyone got one they can loan me haha . yes i'm in sioux falls and joey is a good but from the DSM grave yard and a few other car with blown engines in the front of his shop kinda tells me a little different it kinda makes you wonder bout his quality of work but i have no prpblems with him i've known him since we went to high school but i'm jus trying to keep anyone from workin on my car here word gets around real quick and to much trash talk happen perfer to take it somewhere else and his 2 wheel dyno rates are insain 300 jus to get my car setup to go on the dyno last time i checked. I do most the work myself but AEM EMS is new to me it isn't no AFC2 that easy to tune haha and i've talk to a few guys that have had there car done at gieman motorsports and they have the closest awd dyno i leaning towards them $1000 for install and dyno tune sounds good to me. done once done right thats my saying
Originally Posted by ballistic speed
expect to have that aem retuned often, it's not a done once kinda thing, if you wanted a done one done right, u should have gone with a flash or piggypack
Well, thats if you give enough leway in the tuning, but if ur pushing the envlope of your power output, then you will have to get retunes, if they do a safe tune then yes you won't need a retune but then you won't get a full power output
i did look in on sean ivy accually someone pm him for me just waiting for him to get back to me. if all else fails i'll trailer my car to a tuner. i did manage to get the car to start on saturday when playing with the base line tune the comes in the setup. but doesnt run to well when its starts to boost even at 2 psi the car get all shakky i only drove it around the block i'm thinking it might be because i have no boost settings on the AEM and the manual boost control is still hook up instead of the boost solenoid and i have bigger injectors too accually what was i set it as cause i have buschur racing injectors 780cc but it doesn't show on the wizard and what settings should i change when adding the maf delete parts ?
msg Sean Ivey (Sean I) and tell him your mods. He will make you a base map to your mods and then show you how to do the trimming. If you want a really good base map you will take my advice and contact him
