AEM EMS Get tuning help for your AEM EMS system.
No Lift Shift/2 step in an 05
Old Mar 12, 2006 | 07:30 PM
DragNRacing's Avatar
Has anyone got their AEM to work off the clutch switch so that they can use it to no lift shift? I have the 2 step working but only for launch.
Old Mar 16, 2006 | 10:20 AM
TrinaBabe's Avatar
Yes but I prefer to use the primary rev limiter between shifts Otherwise it seemed to create a lag from when my clutch was let out to when it would allow power again. It kinda seemed like the car was choking power until I was solidly into the next gear causing the car to slow down pretty good between shifts.
Im sure with enough screwing around you could make it timed right... I think my problem was my clutch was engaging too low and the switch was not switching until the clutch was much higher. (If that makes any sense).
Old Mar 16, 2006 | 10:26 AM
TrinaBabe's Avatar
By the way, the only rev limit you can set it to I believe is the 2-step limit. So whatever your launch RPM will be will also be the shift-no-lift.
I havent screwed with it much but Im pretty sure this is the only way.
You shift fast Just bang it!
Old Mar 19, 2006 | 08:55 PM
Your setup is a little different as you don't have the extra limiter switch like I do on the 05 stock. My goal was to use that but don't know which wire on the stock limiter switch would need to go to what input on the AEM EMS. For now I am just going to try it off the rev limiter and see what happens. It would be a little less abusive to the driveline if it was off the 2 step. What input are you using for your 2 step? Do you have the switch set to always on and use the VSS to turn it off or are you using the switch you installed previously? If using VSS, what MPH are you using? What RPM for the two step and what level of cut (1-10)?
