AEM EMS Get tuning help for your AEM EMS system.
quick aem ems help
Old Jun 2, 2006 | 03:33 PM
BANKS's Avatar
quick aem ems help
i need to know a couple things for this weekend,
where did you mount your map sensor (pics help)
the air intake temp sensor
and how did you run the wideband o2 sensor?
and where can i find the GM boost controller??
thanks guys
Old Jun 2, 2006 | 03:50 PM
levo2nr's Avatar
http://forum.aempower.com/forum/index.php?topic=6696.0
check the aem forum lots of info
Old Jun 2, 2006 | 03:58 PM
evolved4g63's Avatar
https://www.evolutionm.net/forums/sh...=speed+density
Theres another. Post #6. Also the easiest thing to do with the map sensor is to buy the 30 dollar adapter from buschur. Instead of drilling a hole in the mani take the stock sensor out then put the adapter in, then screw the map sensor into that. I put my AIT in the lower cold side piping due to heat soak near the TB.
Old Jun 3, 2006 | 10:26 PM
kduncan01's Avatar
Your doing this install yourself? Including the tuning?
Old Jun 4, 2006 | 07:23 PM
Mase's Avatar
i think gmpartsdirect has the solenoid for cheap.
if not, u can get it from any gm dealer
Old Jun 4, 2006 | 07:24 PM
Mase's Avatar
and yeah, u should be able to find a lot of answers plus more on aem's website, if not, specify what you cant find, and i'll help u out
Old Jun 5, 2006 | 03:28 PM
Kerr's Avatar
Fomer Vendor
Mase, Do you have a part number on the GM boost controller? I tried looking on that site and you have to have a part number or know the car it goes on.
Old Jun 6, 2006 | 11:11 AM
racegate's Avatar
G.M Boost control Solenoid part# 1997152
G.M Pigtail for the boost solenoid part# 12102747
Old Jun 6, 2006 | 03:09 PM
Kerr's Avatar
Fomer Vendor
Whats the pigtail for? I searched on their site and it showed category: Radiator Tank Cap and description: connector. And its more than the solenoid. Is it just the connector with bare wires coming out of it? Maybe wrong part number?
Old Jun 6, 2006 | 03:13 PM
nutrulz's Avatar
also since I just battled this, with the GM solenoid, the + side goes to the Green wire on the stock solenoid.
Old Jun 6, 2006 | 04:16 PM
racegate's Avatar
Its the right part number.. and yes its the connector with the 2 wires coming out of it. Its listed wrong on their site.
