AEM EMS Get tuning help for your AEM EMS system.
How to Configure my AEM EMS to use 1000cc injectors??
Old Aug 8, 2006 | 09:18 PM
Blue Evo 8's Avatar
I have a set of 1000cc Precision Injectors, I wanted to know how to go about configuring my AEM EMS so that those injectors will work
Old Aug 9, 2006 | 04:25 AM
8URVTEC's Avatar
Go to setup and chose injector wizard. Then scroll down to find the PTE 1000cc injectors and select it.
Old Aug 9, 2006 | 06:57 AM
jbrown's Avatar
1000cc on a 50-trim???
that's only about 300cc more than you need.
have fun with the idle settings!
Old Aug 9, 2006 | 09:50 AM
Blue Evo 8's Avatar
cool, then after I select it do i need to save the changes?
How will the car idle?
Old Aug 9, 2006 | 01:15 PM
evoate ya's Avatar
I have a 50trim and 1000cc injectors and my car idles perfectly. The injectors are fine.
Old Aug 9, 2006 | 01:18 PM
evo_08's Avatar
the best way to do it is to call sean ivey and make an appt. and have him tuneit
Old Aug 9, 2006 | 01:22 PM
8URVTEC's Avatar
+1
Old Aug 9, 2006 | 01:24 PM
evo_08's Avatar
i have a 35r with 1200cc and it idells perfect
Old Aug 9, 2006 | 01:28 PM
ExViTermini's Avatar
select rochester 1008 in the injector thing. Then go to your fuel map, and right click on it, and ther will be an option for injectors in there.
Put in 43psi, 560cc injectors for original, then 43psi, 1008cc for the new, and let it do the math.
you might have to fine tune it after that...but thats a good head start.
Old Aug 9, 2006 | 01:33 PM
jbrown's Avatar
And I imagine you both tuned it yourselves like it sounds Blue Evo 8 is trying to do?
evo_08's Avatar
sean ivey tune my car
Old Aug 9, 2006 | 01:53 PM
Blue Evo 8's Avatar
All I wanna do is install the injectors and get the car running properly until my dyno appointment
Old Aug 9, 2006 | 03:56 PM
EVO8_PR's Avatar
I have tuned it myself with 1600cc injectores and it idles pretty good.
Old Aug 9, 2006 | 05:24 PM
Blue Evo 8's Avatar
what are the parameters for the XY axis?
Old Aug 11, 2006 | 02:04 AM
macsperformance's Avatar
X axis is the engines RPM
Y axis is the load that is placed on the engine
Chris Macellaro
