AEM EMS Get tuning help for your AEM EMS system.
high sporadic idle and "hanging" rpm..
Old Jul 2, 2007 | 05:24 PM
QuickOne's Avatar
I just installed my EMS in my IX and am having two problems. Both of which only happen occasionally
The first is that at idle, it will rev and old at ~3K rpm. Meaning that on startup it will run up to 3K, or if i blip the throttle it will hold the idle to whatever the highest rpm it hits.
The second thing (and this might be related), is that it will take a few seconds (3-4 usually) to come back down to an idle point if I blip the throttle or come off of the gas/clutch at a high rpm point.
Any ideas??
New EMS, just the base calibration is on it.
Old Jul 3, 2007 | 10:04 PM
alpha's Avatar
Send me your calibration with your setup details. I will see if I cant change anything and send it back to you
Tuning at Inductionperformance.com
Old Jul 3, 2007 | 10:19 PM
Aby@MIL.SPEC's Avatar
you need to establish a decent idle % vs. target table.
then you can plug in most anyones decent idle settings.
here is a screen shot of my current cal file idle settings.
my car is a dd & these settings work for me. i am certain you may get 20 different examples & they may all work too.
just refer to the aem 217 page pdf & learn
Attached Thumbnails high sporadic idle and "hanging" rpm..-aem_idle_settings3.jpg
Old Jul 4, 2007 | 06:32 AM
QuickOne's Avatar
here's my current calibration. It's basically the stock 1320 cal.
File Type: zip
Old Jul 4, 2007 | 08:13 AM
alpha's Avatar
What cams do you have?
Old Jul 4, 2007 | 09:08 AM
QuickOne's Avatar
No cams. The car is 100% stock mechanically.
But i have a 3076R i want to install eventually - just want to make sure this is perfect before i start messing with it.
Also i'm using the AEM to run my AiM dash.
Old Jul 4, 2007 | 11:53 AM
alpha's Avatar
Try this
Old Jul 4, 2007 | 06:39 PM
QuickOne's Avatar
Thanks. I'll give that a try this weekend as i'm going to be away from my ca for a little while. One question though, i was looking at the difference in the changes... Why the change to the fuel map by one point?
Old Jul 5, 2007 | 05:22 PM
8URVTEC's Avatar
I had this problem as well on an 8, but the tuner said that he needed to go directly into the Intake manifold with the map sensor. After they installed directly into the manifold the problem went away.
Old Jul 5, 2007 | 06:12 PM
alpha's Avatar
I might have done it on accident while doing something else. I dont remember honestly
Old Jul 6, 2007 | 06:42 AM
QuickOne's Avatar
Awesome! yes, i will most definitely try your beer-induced tune!
Actually, i will give it a try this weekend as it looked mostly like good ideas. I'm going to spend some time getting it to run properly as i've got a lot to do with it.
Old Jul 6, 2007 | 07:55 PM
alpha's Avatar
hahaha If it doesnt work. Highlight the entire Idle% vs Target table. Right click. Change. -2%. Try that a couple times. See if you make head way
Old Jul 9, 2007 | 12:02 PM
EVOLex's Avatar
Where else would you get Manifold Absolute Pressure if not from the manifold?
Old Jul 9, 2007 | 04:19 PM
8URVTEC's Avatar
They went off of the same place as the boost gauge and T'd it off! Now it is using Buschur's adapter directly into the manifold, no more problem!!!!
Old Jul 9, 2007 | 05:03 PM
EVOLex's Avatar
What is this Adapter that Buschur makes? Do you have a link?
