AEM EMS Get tuning help for your AEM EMS system.
Anyone ever seen something like this in a log ?
Old Jul 21, 2007 | 03:57 AM
gudmundur's Avatar
Hi
I have been experiencing a boost fluctuation and I dont know if it is my turbo or something else, I have exchanged my wastegate actuator, manifold, bypassed my boost controller and exchanged over to another turbo.
But I always have this fluctuation and I am getting to a point where I dont know what to do next.
If someone has seen anything like it .. please share with me your experience or knowledge
Attached is an AEMlog file and here is a picture of one of my logs
http://s3.frontur.com/img/65126/20070713100040_0.jpg
regards
Gudmundur
File Type: zip
Old Jul 21, 2007 | 09:14 AM
2JZfan's Avatar
Try logging "Engine Load" instead of "MAP as Load", see if that looks any different. But the bigger question is, what are you using for boost control? If you are using the AEM to control boost then you need to log those parameters like "Boost Target" "Boost Error" "Boost WG Out" "Boost WG Map", etc...
Old Jul 21, 2007 | 09:28 AM
gudmundur's Avatar
Hi
Thanks for the tip.
I am using AEM truboost to controle the boost, but the fluctuation is the same with my boost controller connected or just running wastegate spring pressure , that is a vacuum hose connected between the wastegate and turbo outlet pipe
regards
Gudmundur
Old Jul 21, 2007 | 01:27 PM
Aby@MIL.SPEC's Avatar
try this
with aempro, open your currrent file, save it as something else, then go:
setup/sensors/manifold pressure sensor/options/mapfilter....
what is your value?
i use 8. this is a internal filter for aem & the map sensor.
Old Jul 22, 2007 | 03:55 PM
gudmundur's Avatar
Omg
Thanks so much for the help WOT.
You were dead on, now my engine load is just a fluctuating up and down about 0,3 psi or so.
I have been battling this problem for weeks so you just put a biig smile on my face
thanks again
regards
Gudmundur
