AEM EMS Get tuning help for your AEM EMS system.
fan speed ?'s
Old Nov 10, 2007 | 08:31 PM
DWAIST's Avatar
fan speed ?'s
is there anyway in the AEM software to control fan speed? i'm looking to run the fans at full speed. right now my fan is running at about half that when using the factory control box.
Old Nov 11, 2007 | 12:30 PM
DWAIST's Avatar
isn't the radiator fan on the evo a two speed? does it kick into high speed at a certain temp?
i did notice if i bypass the control box and wire the fan directly it spins at high speed. but when it's wired that way as soon as i flip the ignition the fan stays on the whole time.
Old Nov 12, 2007 | 03:44 PM
DWAIST's Avatar
24 views and no input.......
Old Nov 12, 2007 | 07:39 PM
GTVEVO's Avatar
Yes it can and it does as long as you wire it into the stock location with the controler attached. The AEM uses the "User defined PW output" to acomplish this along with the coolant temp voltage.
