AEM EMS Get tuning help for your AEM EMS system.
aem newbie problems
Old Jan 4, 2008 | 10:48 AM
05graphiteMR's Avatar
aem newbie problems
first of all....
finally got the car to start with AEM's basemap
most of the dashboard on the laptop is not working properly which makes me think i am missing a whole lot or have not done a whole lot.
the RPM's and TPS don't work
when the throttle is pushed the airflow moves but not the tps (with engine off)
i am sure there is more, but wanted to know if it is a calibration setting for the sensors or if there is something else
no MAF - converted to AEM 5bar map sensor, BBK 70mm TB with new TPS
any help is appreciated, just trying to get bugs worked out so its simpler when i get it up to AMS sometime around march.
and yes i have the massive copy of the instructions, but i might as well be writen in greek the way it jumps around and is not very clear
Old Jan 4, 2008 | 04:32 PM
EVO Tweeker's Avatar
Sounds like a calibration issue. Go back through all the sensor calibrations again just to make sure you have covered your bases.
Question, is the cal file the same as the version of AEM software you are using? (i.e. 1.19 cal with 1.19 software)
Old Jan 4, 2008 | 04:37 PM
evo_08's Avatar
ivey tune my friend.
Old Jan 5, 2008 | 04:54 AM
ivey is too far away.
yes the cal files are the same. i have AEM's base plus a couple of maps from people and all of them do the same thing.
hopefully i can get this figured out before i take it to AMS so they don't have to dick around as much with fixing basic stuff
Old Jan 6, 2008 | 10:24 PM
Sean@Iveytune's Avatar
I no longer do these Base maps.
Sean
kamote2000
Sep 30, 2016 10:50 PM
turboedv6
Aug 29, 2015 06:37 AM
Ekoy
AEM EMS
Apr 21, 2009 07:17 PM
2003evo8
AEM EMS
Apr 4, 2006 12:07 PM
